Results 1 to 13 of 13
Thread: Adding a lot of salt. Normal?
    Mar 2015
    Orlando, FL
    14
    I'm adding ~1 40lb bag every 2 weeks. I'm in Florida but pool is unused now. I have the pump run down to 4hrs and I've set the SWG to its lowest setting. I have no trouble maintaining good Cl levels. I've had my salt levels manually tested to be sure the SWG wasn't misreading too.
    Is this normal? Any rules of thumb on consumption rates of salt?
    Pool is ~25k gal exposed agg. IG
    SWG = purechlor
    IG 25k gal. w/ screen enclosure
    Sta-Rite/AOSmith 1.5hp pump
    Pentair 200sqft cartridge filter
    SWG PureChlor 40k gal rated(aka Solaxx/Reliant)
    JoyfulNoise's Avatar
    May 2015
    13,258
    Welcome
    Unless you are getting torrential down pours resulting in feet of water overflowing your pool, you should not be adding that much salt that frequently. If you are actually losing that much salt then i think you have a leak.
    Do you have a pool auto fill? How much water does you pool lose normally and how often do you top off?
    Honestly, you will not find anyone here that puts much credence in pool store testing. TFP is all about testing and adjusting your water chemistry yourself.
    Have you checked out Pool School and read through that section?
    Matt
    Jun 2011
    Long Beach, CA
    2,790
    Re: Adding a lot of salt. Normal?
    Do you know what the CYA level has been doing? The CYA, salt level, and perhaps the CH level will all be changing if the pool is losing that much salt.
    With our dry conditions I've only added the extra 3 bags of salt in 5 years.
    Mar 2015
    Orlando, FL
    14
    I definitely am not losing water/salt to rain overflow.
    I don't 'think' I have a leak. I tried the bucket comparison as recommended in the pool school section. After 4 days the bucket is ~1 inch higher than pool. (so ~ .25"/day difference). My neighbors seem to think that difference is borderline normal since my pool receives varying amounts of sun while bucket was mostly shaded. No auto-fill so I'm aware of amount water added
    My CYA is about 70ppm now. I'm adding stabilizer roughly every ~3-4months. CH is 400ppm. My city water is naturally high in calcium.
    This is my first pool and I've only been in this house for 1year so I don't have a lot of perspective/history to draw on. Also, when I first moved in I had the pool resurfaced, SWG added, filter and valves replaced. So everything is relatively new and working well.
    What do you guys think? Leak? Hyper-active SWG? Aliens?
    May 2015
    13,258
    So let me ask you this - when you add salt, who or what is indicating that your salt is low?
    Matt
    Mar 2015
    Orlando, FL
    14
    There is a low salt indicator on the SWG. I've verified its accuracy by testing samples at a pool supply store (I don't have a kit test for salt myself)
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Did I miss something? If the pool is 1" lower than the bucket after just 4 days, you have a leak. Otherwise they would be the same water level. Sun versus shade makes no difference for evaporation.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2013
    Sacramento, CA
    2,769
    A low salt indication can mean several things besides low salt.
    First, I strongly urge you to get one of our recommended test kits (a TF 100 or the K- 2006) and a Taylor Salt Test kit K-1766. Pool store testing is generally not reliable. I suspect your salt is high. How old is the salt cell?
    Second, unless you are getting massive amounts of rain and huge evaporation you have a leak. Sounds like a small one. I'd let the pool drop until it is below the skimmer. If the leak drastically slows then its the skimmer. That rate is so low it will be difficult to tell with a dye test. Do you have bubbles coming out your returns or air in the pump basket?
    May 2015
    13,258
    Quote Originally Posted by gwegan View Post
    +1 ^^^^^^
    Best advice yet!
    Matt
    Mar 2015
    Orlando, FL
    14
    Salt cell is less than 1yr.
    I'll try letting it drop as you mentioned and see if there is a difference in rate of loss
    There is a small amount of air in pump basket and out the returns. New gasket on the pump basket cover so I'm pretty sure not entering there. Think I have supply side leak? The guy that resurfaced my pool and replaced a lot of kit said a small amount of air is normal. I assume now that was BS. If supply side leak would I only lose water when pump is off?
    Jun 2011
    Long Beach, CA
    2,790
    All things are pointing to a slow leak, the bucket test, needing to add CYA every 3 months, and needing to add salt. There is still a chance that the SWG is not reading right and the pool store salt test is wrong.
    Here is a write up on suction side leaks, Pool School - Suction Side Air Leaks.
    Apr 2013
    Sacramento, CA
    2,769
    Ping has a good analysis above. Read the pool school article and let the water drop below the skimmer.
    Mar 2015
    Orlando, FL
    14
    Ok thanks to everyone for input. I'll see if I can track this down
