Thread: Single color light to replace Jandy CPHVLEDS50
    Dec 2015
    Rocklin/CA
    6
    I want to find out what options are available to replace my Jandy CPHVLEDS50 multi-color light. It's died the end of last summer (I can hear the relay, but no light). I'm looking for a lower cost option, and would be fine with a single color solution - preferably one that enables an affordable bulb replacement the next time it goes out).
    I have a Jandy PDA system with v4.1 firmware.
    Dave
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Single color light to replace Jandy CPHVLEDS50
    Welcome to the forum Dave
    Someone should be along soon with some help for you.
    Solar Blanket, Well Water, Borax Added. 68
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Agreed that the Jandy LED is a pricey light option, both new and when you have to replace the "light engine" when it goes bad ($499...what the??).
    You will need to buy a new pool light assembly (housing, lens, gasket, circular face trim, 300w or 500w bulb). Google "Pentair-Amerlite" pool light. For about $200/$250' you'll get a 120v pool light assembly with 50'/100' of wire that you will have to splice into your existing wire and pull it through. (i.e., you won't be able to just hook up a new light to the existing wire that now runs from the light to the pool panel power source).
    With this set up, you have several options. You can stick with just the plain white bulb; or buy a colored lens kit if you want a colored light; or for about $169, you can buy a reasonably priced screw-in multi colored led light bulb (Google "BulbWizard).
    This set up won't have you breaking the bank when you have to replace either the plain light bulb or the LED light bulb.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Dec 2015
    Rocklin/CA
    6
    Perfect ... that's just what I was looking for. I like having the option to go back to multi-color LED with this setup.
    Thanks for the help,
    Dave
