Results 1 to 11 of 11
Thread: Got the test kit!
    cclay's Avatar
    Dec 2015
    Burleson Texas
    9
    Got the test kit!
    It's like Xmas morning!!!!
    15,000 Gal Gunite pool/ Jandy Pro Series Stealth 2HP/ Jandy DEL60 sand filter/ Polaris PB4-60
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Got the test kit!
    Congrats to you, and Merry Christmas!
    Essential Links:
    cclay's Avatar
    Dec 2015
    Burleson Texas
    9
    Results as follows.
    Salt- 3400
    CH- 525
    CYA- 70
    ALK- 150
    Chlorine- 2
    CC- 0
    TC- 2
    PH- 7.8-8 hard to tell
    I knew my chlorine would be low, I haven't added in 2 weeks since I found this sight. I am going to use bleach, store brand, the question is what's the dosage and how should I broadcast.
    Any other things I should add based on test results?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Congrats on the new Light Saber. Now you need to read up on Pool School and use our Pool math app (top of page) for it's operating instructions! It'll tell you how much to add for your gallons size to achieve what result you are looking for. Pour bleach slowly in front of a return with the pump running.
    Mar 2015
    South Texas
    411
    According to poolmath 1 gallon and one cup of 8.25% will take you to your target, which is 8 for your CYA. I would just add a gallon and a half (or so) and test it again in a couple of days. Shoot for 8 ppm, don't want to go lower than 5. HTH. Oh, and Merry Christmas to you!
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Casey's Avatar
    SW PA
    10,461
    Enjoy the kit! Merry Christmas!
    Aug 2014
    Northern IL
    4,615
    Is your water clear? Any signs of algae?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    How exciting!
    Fix the pH first because your CH is heading high and the high TA will tend to drive pH up fairly quickly and that's a recipe for scaling. Then raise FC up to the right level for your CYA.
    You don't need to broadcast liquid acid or liquid bleach, just dribble it into the pool in front of a return jet while the pump is on and it will spread out and dilute. A few sweeps with the brush will speed it along. Give yourself half an hour between chemical additions.
    Have you read Pool School - Recommended Pool Chemicals ? That tells you what chemical does what and how to add it.
    cclay's Avatar
    Dec 2015
    Burleson Texas
    9
    Quote Originally Posted by MarianParoo View Post
    Crystal Clear... No signs at all.
    Quote Originally Posted by nlindelldc View Post
    I was thinking I read 4 as a target.... Glad you told me that, I will dose today accordingly. Thanks to all. Merry Christmas!
    Jun 2011
    Long Beach, CA
    2,790
    See my signature for the Chlorine/CYA chart.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    cclay you might want to add the info on your SWCG to your signature. I'm not sure if the recommendations you're getting are with the knowledge you have the Polaris autoclear ??
    With a SWCG and your CYA at 70 you should never drop below 3 and have a target of 5 ppm FC.
    Have you done anything to bring the pH down yet ??
    Solar Blanket, Well Water, Borax Added. 76
