Thread: Pool Upgrade
    Jul 2015
    Tampa, FL
    18
    Pool Upgrade
    Greetings and happy holidays to all! I am planning on getting my pool resurfaced /painted this winter, and was wondering if anyone knew of a good contractor (orthree) working in the Tampa, Florida area? Thanks in advance for the help!
    10,000 Gallon Pebble Tec
    Hayward Star-Clear Plus C900 cartridge filter
    Hayward 1.5 HP pump
    Pool is filled from city water
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: Pool Upgrade
    No help in finding a contractor except to maybe call some pool builders and ask who there plaster person is. I wonder if you could call the makers of the plaster you are thinking of going with and see who has used their products in your area before?
    I do want to say I encourage you to go with resurface of the plaster instead of painting. Painting has been shown to be a shorter term fix. I bet you could do a search to find painted pools to give you some real life experiences.
    Kim
    Jul 2015
    Tampa, FL
    18
    Re: Pool Upgrade
    Kim,
    Great idea, I hadn't even thought about going from the plaster backwards. I agree with you on the resurface, as we're planning on being here a while, we might as well get it redone now rather than later.
    Wade
    Hayward 1.5 HP pump
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool Upgrade
    Kim has a good idea. For example if you go on PebbleTec's website they will give you a list of installers in the Tampa area. Many of them install other products also.
    We find that paint has AT BEST a three year life. The usual life is only really a year.
    Casey's Avatar
    SW PA
    10,423
    Re: Pool Upgrade
    Painting a pool should be illegal.
    Save your pennies and go with the plaster every time. Good luck finding someone.
    Jul 2015
    Tampa, FL
    18
    Re: Pool Upgrade
    Thanks to all for the recommendations, I'm going to start shopping around after the New Year.
    Hayward 1.5 HP pump
