Thread: Floor drain cover
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Floor drain cover
    I have twin drains in the floor of my pool, my pool depth is only about 5ft deep. These drains have a dome type head on them, and walking across the pool you could stub your toe on them, does anyone know if they make a lower profile cover that might work? Any other ideas?
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Floor drain cover
    Pool and spa drain covers are designed to prevent entrapment. Unless you have two drains that relieve the pressure, a single drain probably needs to be bowed up or extremely large to make it harder to complete a seal over the top of it.
    All Drain covers must be Virginia Graeme Baker Compliant
    Support the site
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,751
    Ooops, I guess you are just looking for replacement drain covers. If that's the case, all of them protrude into the pool by 3/4"-1"
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Apr 2013
    Sacramento, CA
    2,769
    As noted above, all the vgb compliant covers for twin suction drains protrude above the pool surface. If you want to cut the plaster and do a little surgery on the pool there are a varity of solutions (like troughs) that are vgb complaint and do not stick up.
