Thread: SWG for my pool
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    200
    SWG for my pool
    I want to convert to a SWG, what I am reading is that you want at least 1.5 x the pool size. Best that I can tell is the AquaRite AQR15 with the T-15 (40k rated) cell is the best way to go but that isn't going to give me the 1.5 ratio. Is that going to be an issue, will i have to run my pump all the time to keep the chlorine levels up? Looks like the pool pilot has a 52,000 gallon solution, would that be a better solution? Thanks
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: SWG for my pool
    I would say twice as big or more. A larger salt cell allows you to run it and your pump less. For a 30,000 gallon pool I would be looking at cells that are rated for 60,000 minimum.
    Remember, salt cells have a finite life span and will need to be replaced at some point. Figure that into your calculations.
    Remember, while I agree automated chlorination is wonderful there are other options. I love my Stenner Pump, but I still have to carry jugs to keep the tank full.
    Support the site
    Jun 2011
    Long Beach, CA
    2,788
    Re: SWG for my pool
    The PoolPilot will be a good size for your pool. The Aquarite will do fine for most of the year but for 2 months during the summer you will have to run it a little longer than the PoolPilot.
    Do you know how much chlorine the pool averages a day during the summer? The AquaRite can produce about 5.5ppm of FC and the PoolPilot can produce 8ppm of FC in 24 hours for a 30,000 gallon pool.
    Another option is installing two AquaRites and cut the run time to a few hours a day, but I would just go for one for a year to see how it works out.
    Jun 2015
    York SC
    200
    Re: SWG for my pool
    As to the stenner pump, I have researched those and what it comes down to is that I dont have a place to put the chlorine storage that isnt hot and in direct sun. The pad isnt close to the house and gets direct sun for most of the day in summer. Not sure how to work around that.
    For chlorine use, I only have a months experience in sept and it was pretty hot. At that time it was consuming a steady 44 oz per day. But, I am continuing the fight to lower my cya and at that point it was about 100 (down to 80 now so slowly making progress). I will take a look at the pool pilot. Thanks
