Results 1 to 16 of 16
Thread: Pool has a greenish/yellowish tint
    Feb 2010
    South Alabama
    27
    My pool pump was not working recently and my pool went about three weeks without running. I do not close my pool for winter because, living in the south, we still like to sit outside!
    When i got it to start working again, it turned a greenish/yellowish color. It's not cloudy....I can see the bottom. I thought it may be algae, so I hit it pretty hard with bleach. Nothing happened. I have a lot of trees, so leaves and acorns are always in it (I clean it every day), so I thought it may be something else.
    I've tested it and double checked it with a pool place, and no metals, no algae (if there was, I killed it with Clorox)!
    FC: 18
    CC: 0
    Ph: 7.8
    Hardness 145 (I know that needs to come up, but after FC comes down)
    Alkalinity: 70
    Cya: 40
    I also have air bubbles in the pool. I'm going to check o-rings on pump today.
    My main concern is the color! What could it be?
    10,620 gallons/IG/plaster
    SWG
    Cartridge Filter
    Ozonator (only because PB wanted my business!)
    Pump 1.5 HP (2-speed)
    Casey's Avatar
    SW PA
    10,438
    Re: Pool has a greenish/yellowish tint
    Ok... tell me this... when you take the brush n push it across the bottom of your pool, what does it do? Do you see any poofing plumes?
    Go out right now and report back.
    Feb 2010
    South Alabama
    27
    Nothing that I would report as a proofing plume! Nothing happens.
    SWG
    Cartridge Filter
    Casey's Avatar
    SW PA
    10,438
    Lay a Vitamin C tab and a puck (in a seperate area) on the step for several minutes. See which one lifts the green. Report back.
    Also, take a pic of the pool walls and the floor and the area you brushed.
    30,419
    Despite tests that show no iron, it sounds like the sudden addition of chlorine has precipitated iron in your pool. I would simply allow the FC to come down and I believe the color will disappear as the iron returns to solution.
    Feb 2010
    South Alabama
    27
    image.jpgThe walls/bottom isn't green, it's in the water. And when you say 'puck', do you mean chlorine puck?
    I certainly hope so Duraleigh, but I'm not too patient when my pool looks like this! ��
    SWG
    Cartridge Filter
    Casey's Avatar
    SW PA
    10,438
    What's your water source? Sure does look like Mt. Dew.
    Feb 2010
    South Alabama
    27
    Lol....then my kids would love it!! ���� I'm on city water....never had a problem before!
    SWG
    Cartridge Filter
    Feb 2010
    South Alabama
    27
    I did just rub a vitamin c tablet on the step and it rubbed some yellow off! Should I do an acid wash?
    * I meant ascorbic Acid treatment!
    SWG
    Cartridge Filter
    30,419
    Take it one step at a time. Your picture confirms (to me) that iron has precipitated out of your water. Simply letting the FC drop and running the pump 24/7 should take care of it.
    Once that's done, then you can work on any remaining stains.
    Casey's Avatar
    SW PA
    10,438
    Well, wonder where it came from?
    Feb 2010
    South Alabama
    27
    I wish to heck I knew!
    SWG
    Cartridge Filter
    Aug 2014
    Northern IL
    4,615
    I think you might want to test your refilling water to see if that has iron.
    Casey's Avatar
    SW PA
    10,438
    Quote Originally Posted by Maddie View Post
    At least you have a plan right now. Filter n let FC come down n see where it goes from there.
    30,419
    I have tested my refill water quite a few times for iron with the Taylor iron test.
    It never shows that I have iron......yet over the years, I have accumulated enough iron staining on my liner pool to do an Ascorbic Acid Treatment.
    The treatment worked wonders but I just have to assume the Taylor test will not report very small amounts of iron.......I have no other explanation.
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    My experience has been the same as yours.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
