Results 1 to 10 of 10
Thread: Hot tub not getting oxidized by ozone thingy
    Oct 2015
    Kelowna BC
    47
    Opened the side panel today to start draining and noticed that there was an air hose disconnected. Upon further investigation I found that the plastic nipple that attaches to the ozone injector had broken off. So the hot tub hasn't been getting oxidized! I replaced the nipple, cut the hose and re-attached it. There is a slight noise coming from the air tube, like there is a bit of water in it, is this normal as it's pushing the oxidized air into the water somewhere?
    By the way, how does this ozone thingy work? Should it be cleaned? Does it have a filter? Should something be re-charged or filled? This hot tub is from 1994 and we bought the house about a year ago, so just wondering what the maintenance is on this. Thanks!
    Sundance Calypso Hot tub 1500 L, 2 pumps, Taylor K-2006 test kit
    Nov 2015
    VT
    85
    Re: Hot tub not getting oxidized by ozone thingy
    Yes. it is supposed to inject ozone into your water.
    Ozonators usually last @ 3 years. They don't require any maintenance/service.
    You can buy a test kit to see if it's working or not.
    Hot Springs Sovereign (1999?)
    Oct 2015
    Kelowna BC
    47
    Quote Originally Posted by Brian VT View Post
    Since the tub was bought in 1994, should I assume that it's never been replaced and just replace it? Just wondering how much a test kit would be to test it?
    Aug 2014
    Shallotte, NC
    693
    The ozone generator is probably cheaper than the test kit....
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Quote Originally Posted by ewkearns View Post
    And in my opinion just skip replacing it. I have had tubs with and without them and never noticed a difference.
    I just follow these instuctions: How do I use Chlorine in my Spa (or pool)?
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,251
    A properly functioning ozone generator can cut the amount of chlorine needed to oxidize bather waste in half. The downside to them is that, if they run all the time or if there is no way to control their run times, the ozone will react with chlorine and convert it to chloride when the tub is not being used by anyone and that will create an excess chlorine demand. Then there's also the on-going replacement costs assuming they still make replacement units for a tub that old. The ozone generator on a tub that old was probably intended to be used with bromine sanitation as ozone can oxidize bromide to bromine thus helping to keep bromine sanitizer levels up.
    Honestly, I'm not sure it's really worth replacing it in your case.
    Matt
    Oct 2015
    Kelowna BC
    47
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    So uses up the free chlorine too quickly without using the tub or any load? Should I just unhook the air hose from it then?
    May 2015
    13,251
    Quote Originally Posted by davesurfer View Post
    If it generates ozone all the time and the ozone is added to the water, then yes, ozone will react with chlorine and convert the chlorine into chloride. Typically you don't want to sit in a bubbling hot tub with ozone in the water as its not healthy to breathe in. So I'm not 100% when they actually turn on or off.
    However, in practice, I think most people with hot tubs that have ozone systems find them to be entirely useless - many say they could see no difference in water chemistry with or without them. So I wouldn't recommend that you go to too much trouble with it. Just disconnect the power supply and leave it be.
    Matt
    Sep 2012
    Pittsburgh
    35
    I have had my ozone generator disconnected for 6 years. I just use bromine tablets and non chlorine shock and get really good water quality.
    Oct 2015
    Kelowna BC
    47
    Quote Originally Posted by Awilli8203 View Post
    Good to know thanks! I've disconnected it, don't see the little bubbles trailing up any more and it's quieter. I'll see how this affects the water chemistry with regards to the FC being used up...
