Results 1 to 9 of 9
Thread: Clor MorŽ Septic Tab
    Oct 2015
    San Diego, Ca.
    648
    Does anyone have any experience with Clor MorŽ Septic Tabs?
    Are they a substitute for standard 3" pucks but do not contain the CYA?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    JoyfulNoise's Avatar
    May 2015
    13,222
    Re: Clor MorŽ Septic Tab
    They are calcium hypochlorite tabs that will add calcium to your pool water. Also, cal-hypo typically can not be manufactured as tablets without a special binder material. It usually leaves a very sticky and gooey residue when all of the cal-hypo dissolves.
    You really can't use these as a trichlor puck replacement as the left over binder will clog the tubing on an inline feeder. Putting them in a float will leave residue all over your pool.
    Matt
    Casey's Avatar
    SW PA
    10,448
    You really can use these as a trichlor puck replacement as the left over binder will clog the tubing on an inline feeder. Putting them in a float will leave residue all over your pool.
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Ewwwww.
    30,424
    Cal Hypo tablets are for septic use and should not be used in pools......period (For emphasis. just repeating what JN has already said)
    Aug 2014
    Shallotte, NC
    693
    Septic and pool should not be used in the same sentence....
    Casey's Avatar
    SW PA
    10,448
    May 2015
    13,222
    Quote Originally Posted by ewkearns View Post
    Have a birthday pool party for ten 1st graders and you'd probably be better off swimming in your septic tank
    Matt
    30,424
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Also... do not put cal hypo based tablets in the same container or a container that was used for trichlor tablets, including an in-line chlorinator. The results could be explosive. Literally.
    Pool Chemical Explosion Accident Analysis and Investigation at chemaxx.com
    Isolated Spa - 345 Gallons
