Thread: Dirt Cheap pumps on Ebay
    Replaced the motor on my pump a year ago and it has burned up again.
    It is an antique pump and I am going to buy a new one.
    It is very tempting to try one of these pumps on Ebay since they are so cheap. (I know you get what you pay for)
    But
    Sometimes you pay more than you need to.
    Anyone had any experiences good or bad with these units?
    1 5HP in Ground Swimming Pool Pump Motor w Strainer High Flo Hi Rate Inground | eBay
    2 5HP in Ground Swimming Pool Pump Motor w Strainer High Flo Hi Rate | eBay
    2HP in Ground Swimming Spa Pool Pump 5850 GPH Dual Voltage Motor 2 Thread NPT | eBay
    25,000 Gal In ground
    Ceramic Tiled
    FKAA (Municipal) Water
    Sand Filter
    ! Hp No Name Pump K2006 Test Kit
    Re: Dirt Cheap pumps on Ebay
    Good luck at getting parts.
    Jan 2012
    340
    I wouldn't want to be the guinea pig. With that said, most pumps use one of 4-5 shaft seals. Same with motors.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    May 2009
    Youngsville NC
    395
    Yes - you do get what you pay for especially in pool pumps.
    Think of your pool pump like the heart of your pool's circulatory system - cause that's EXACTLY what it is. I would not scrimp here - false economy. Even if you just get a single speed pump, get one of the name brands. You can save money with a 2 speed and save even more with a variable speed. But again - I'd get a name brand pump, not a cheap knockoff.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    356
    I do like eBay and you may just get lucky and get a good one for cents on the dollar but... What if...
    I just installed a new pump for a solar heater and it just didn't sound right. It is good pump brand from a local pool company, they came out and I had a new one up and running within an hour, happy days.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
