Results 1 to 7 of 7
Thread: Drain cover with pebble top?
    lastdon87's Avatar
    Jul 2015
    Sierra Vista, AZ
    54
    http://www.poolfittings.com/channel-pebble-top/
    I guess A&A manufacturing makes a channel drain cover that is slightly carved out and designed to have your plaster/pebble material put it, thus making the drain virtually hidden. Seems like an awesome idea, I was just wondering if anyone has one installed or heard about them, either good or bad. Thanks in advance!
    34x22 freeform, 94'/20,200 gallons, 3.5' to 6', Mini Pebble Aqua Blue, 8' lagoon shelf(18"), A&A in-floor, Venturi skimmer, A&A channel drain, 3 returns, VS3050 pump, Pentair CC420 filter, AQR 15 Salt System, 1 Intellibrite 5G light, 1 globrite in shelf, Heat Siphon Z575HP, 24" sheer decent, Decking will be stained salt finished concrete
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Drain cover with pebble top?
    I don't recall, but I don't look at build threads like I used too either. Seems like a great idea though.
    Essential Links:
    Jan 2014
    Buckeye AZ
    807
    I have one, let me see if I can find a pic....
    [IMG][/IMG]
    it's flush, I run the brush straight across it all the time. It has a pretty low suction; the pipe is connected on one side, so there's probably not much suction on the opposite side of the ring, but that's also due to newer safety standards.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Thats a becoming more and more of a standard feature for pebble finishes these days. They look great and are no different than a standard cover
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    lastdon87's Avatar
    Jul 2015
    Sierra Vista, AZ
    54
    Cool, thanks for the info! I'm going to make sure my PB does one for our pool...
    Jan 2012
    340
    Looks like BuckeyeChris has the Aquastar 20" full circle.
    AquaStar Pool Products - VGB Series Round Outlets
    I prefer these over the covers with aggregate in a tray like in the link posted.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    lastdon87's Avatar
    Jul 2015
    Sierra Vista, AZ
    54
    Quote Originally Posted by thepoolman View Post
    Can you share the reason you don't like the aggregate in the tray option? Does it not last, or start to chip out? Thanks for your insight...
