Thread: Emerson Pump wiring
    Dec 2015
    Dallas
    1
    Emerson Pump wiring
    Hello guys. I took my old pump to a repair shop and they removed the wires and did not put it back. Now that I got my new pump I don't where the wir s should go except for the green( ground). Hope someone can help. Thank you in advance.
    Jan 2012
    340
    Re: Emerson Pump wiring
    If you have 220V service, it does not matter which wire (white or red) goes to L1 or L2. If you have 110V, see the wiring diagram.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    The wires go to L1 and L2 in either case. You move the voltage selector switch to match your supply voltage.
    Support the site
    Dec 2015
    Miami FL
    7
    If you want to be 100% sure, get a Multimeter and Non-Contact Voltage Tester. Using the Multimeter, it will show you the voltage. The Non-contact Voltage tester will only show you if the line is a Hot line or Neutral. Best to test with the Multimeter, I just like having the non-contact voltage tester to check the lines, even after I turned the breaker off. Just remember to be very careful when your working with electricity.
    http://www.amazon.com/INNOVA-3320-Au...rds=multimeter
    http://www.amazon.com/Klein-Tools-NC...Voltage+Tester
    9000 gallon (18X13), IG (in ground) Plaster, Cartridge Filter
    Pentair Pinnacle High Flow Pump PFII-P1-3/4, motor USQ1072 3/4HP
