Thread: gluing jandy check valve to pentair 3way valve
    Diver's Avatar
    May 2011
    South of Boston
    450
    are there any problems gluing those together without any pipe/coupling in between? provided i remove the guts of each before that? i would glue it to intake port of the 3way valve, so any residual glue that might get in should be away from the diverter.
    jandy valve instructions for 1-1/2" - 2" valve says connect directly to 1-1/2" pipe and use coupling to connect to 2" pipe for some reason. even though it seems that 2" pipe would fit just fine..
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: gluing jandy check valve to pentair 3way valve
    The three ports and check valves accommodate 2 sizes of pipe. The 1-1/2" versions accept 1-1/2" directly into the port or a 2" coupler glued over the outside of the port to accept 2" pipe. 2" pipe is the same size as the valve port which is why you need a coupler.
    The same holds true with the 2" (2-1/2" coupler to the outside) and 2-1/2" (3" coupler to the outside) valves.
    I suppose you could glue a check valve directly to a three port valve but I could see having issues with the glue and primer fouling the check valve flapper and/or the three port valve since they are in such close proximity....in addition to looking odd
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Diver's Avatar
    May 2011
    South of Boston
    450
    Quote Originally Posted by bdavis466 View Post
    that's the concern I have, but i think i could try to be neat about it. i plan on putting 2 check valves, 3way valve and actuator in the ground in the sprinkler junction box. it's tight and putting check valve and 3way glued together helps...
