Results 1 to 19 of 19
Thread: Silly robot question
    Smykowski's Avatar
    Sep 2011
    3,065
    Hi everyone,
    Sorry about the hiatus, but now that work has finally settled down, I'm back in "thinking about pools" mode again.
    I'm going to buy a robot before opening this spring, and so far it seems like the best choices for me are either A. Gamble on a SmartKleen or B. spend a little more on either an Aquabot or a Dolphin. I haven't decided which to do yet, but I did run across a question that didn't get answered in all of my reading.....
    The robots are all listed as either "in-ground" or "above ground". Is there really a difference? Is there any reason why I can't buy an "inground" robot for my above ground pool?
    Thanks.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Silly robot question
    Another thing to watch for about the "inground" robots, is that the manufacture states teh type of surface, i, e, all surfaces or plaster. The more powerful robots with multiple scrubbers may be too harsh on a vinyl liner.
    Last year, another TFPer (cant remember his name) asked the same question as you are asking. He ended up getting a Dolphin Nautilus for his above aground, and he never posted any negative feedback about it. So I guess it works fine.
    Personally, I do not know why a inground robot wont work in an above ground pool. For the life of me, I dont know why it wouldn't.
    Divin Dave,
    mas985's Avatar
    Pleasanton, CA
    11,737
    I also thought it was because some of the in ground cleaners have brushes which might damage the AG liner. Most AG robots that I have seen don't seem to have the brushes.
    Mark
    Smykowski's Avatar
    Sep 2011
    3,065
    That's kinda what I thought too.
    Can anyone give any insight into what kind of brushes are on the nautilus? Or better yet, anyone have a Nautilus on a vinyl pool?
    30,403
    I think the distinction in IG and AG cleaners continues to blur. It seems it used to be the wall climbing ability that made a cleaner an IG.
    I don't think they make a robot now that can't be used on any surface....not sure.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I know mine will climb a vinyl walled pool no problem. Can't imagine why it wouldn't in an AG pool.
    Essential Links:
    Aug 2014
    Shallotte, NC
    693
    First, the general: http://blog.poolcenter.com/article.aspx?articleid=6514
    And the specific: We have the Dolphin Nautilus and love it. To answer your specific question (AFAIK), the robot uses 3 different brush/climbing ring combinations.... and they tailor them for your pool surface. The robot actually travels on the climbing rings, situated at the outboard edges of the brushes. I know this because my Nautilus slowed down in forward and reverse motion and refused to climb the walls. Four foam rings later and it was like new!
    Here's the parts breakdown: http://www.inyopools.com/parts_maytr..._nautilus.aspx
    Smykowski's Avatar
    Sep 2011
    3,065
    Great info.
    One more question for the Nautilus owners....
    Based on the link above, it looks like parts are readily available. Is it easy to work on, both for replacing wearable items and for other repairs? No matter what robot I buy, I fully intend on doing all of the maintenance and repair work myself.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    The difference between a Hayward Navigator for plaster vs vinyl:
    They are identical except the shoes that move it around.
    Plaster cleaner uses nylon shoes
    Vinyl cleaner uses cork shoes
    Dolphin E10 Cleaning Robot.
    Smykowski's Avatar
    Sep 2011
    3,065
    When you buy the robot, does it come with all the different brushes/shoes? Or do you have to buy them separately?
    (It's amazing that it's so hard to find these answers from the vendors/manufacturers.)
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by Smykowski View Post
    Great info.
    These folks have you covered....
    Maintenance
    Operation
    Impeller Replacement
    Impeller Cover Removal and Replacement
    Bottom Lid R&R ... Filter Accesss
    Rottom Lid Assembly Parts R&R
    Tracks R&R
    Cartridges R&R
    R&R Combined Brushes
    Aug 2014
    Shallotte, NC
    693
    Ours came with everything... including two sets of filters....
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by ewkearns View Post
    This was exactly the info I was looking for. Thanks for all of it.
    Now I need to watch prices and see if I can find a preseason sale I can pounce on.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a Nautilus and it works great on my IG Vinyl. And it climbs the walls. Its going 3 years now and I havent had to replace any parts at all.
    The scrubbers and tank tracks are soft rubber.
    Dont know who available the Nautilus will be from now on. The Nautilus Plus is the latest version and its about the same price as I paid for mine. 575sih if I recall.
    The Nautilus plus has the same drive system and scurbbers, but has a top loading filter and a handle to help assist getting it out of the water.
    Let me tell ya, I wish I had a handle. It gets tiresome having to grab it with both hands and pull it out.
    Great info.
    Sent from my SGH-M919 using Tapatalk
    Divin Dave,
    Aug 2014
    Shallotte, NC
    693
    * I forgot to add this. One of the shortcoming of the robots shown is that the filter door is on the bottom. The newer units (probably more $$$$) have the door on the top. The older units are OK, but you really need to get into the pool and flip them upside down to take them out for cleaning. Otherwise they drop a lot of sand sized stuff (if present) from the filter.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The new Nautilus Plus has a top loading filter. And the price point from what I read is 575 - 600. Not too bad if you ask me.
    If mine ever bites the dust, Im gonna get me one
    Divin Dave,
    Aug 2014
    Shallotte, NC
    693
    Let me throw in another "trick" I read somewhere.... as the sun comes up, put the wire on the pool apron and let it heat with the sun. It will become very pliable and you can remove any twists and kinks....
    Big thumbs up on the AquaBot
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    Jun 2012
    Lafayette, Ca / USA
    260
    Quote Originally Posted by cjd3060 View Post
    Sent from my SM-P607T using Tapatalk
    Which Model Aquabot ? The only one I found is Discontinued >> ABTRT2R1 Turbo T2 - $1,129 Amazon
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
