Results 1 to 7 of 7
Thread: CSI and balanced spa water
    Mar 2015
    Dallas, Texas
    133
    Does the csi number matter for above ground spas or is that more important for inground pools?
    Reason I ask is my,hot tub is at -.8 csi. Partially because my TA is 40. But for some reason having the TA any higher than that causes the PH to always be around 8.
    Build in progress: 31x18 GI (17,336 gallons) / Diamond Brite French Gray finish / Flagstone Coping / 30ft weeping wall with 7 stations plumbed / Salt Finish Deck / Pentair EasyTouch Controls / Pentair IntelliFlo Variable Speed Pump / Pentair D.E. Filter 60sft / Polaris Automatic Pool Sweep w/ Booster Pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: CSI and balanced spa water
    Is it a stand alone fiberglass tub? No, CSI is not important. Especially not a negative CSI. It is only important in plaster pools and spas.
    Mar 2015
    Dallas, Texas
    133
    Quote Originally Posted by pooldv View Post
    Yes it is a stand alone.
    JoyfulNoise's Avatar
    May 2015
    13,171
    If you added 50ppm borates to your water, then you might be able to raise your TA up to 50-60ppm since the borates will act as an additional pH buffer. Then you can probably get your CSI a little higher.
    Matt
    Mar 2015
    Dallas, Texas
    133
    Any advantage to do this or since csi isn't a problem should i leave as is?
    DFW, TX
    24,450
    Borates are a nice add for a variety of reasons. We use them in our pool and hot tub. Here is a write up on borates, Borates - Why and How.
    Here is the process we have used for two years to maintain our hot tub, How do I use Chlorine in my Spa (or pool)?, we are very happy with this method. We also add epsom salts.
    May 2015
    13,171
    Quote Originally Posted by daveooph View Post
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    It is highly recommended to use them in a chlorine spa. Borates add to the buffering capacity of the water and are very good at slowing down pH rise. In a hot tub, as you have found out, you typically want to keep your TA low as the outgassing of CO2 from the hot, jetted water creates a large pH rise. The problem is, if TA is too low, you can crash it to 0ppm and, in turn, crash your pH as well. So borates not only add buffering capacity against pH rise but also let you operate at a lower TA without fear of crashing the pH. They are also considered a supplemental algaecide and so you might see reduced chlorine demand using them as well.
    As pooldv pointed out, there is a sticky on the use of chlorine in hot tubs and part of that sticky talks about the benefits of adding borates.
    Matt
