Results 1 to 20 of 20
Thread: CH Drop
    Oct 2015
    Burleson, Texas
    178
    CH Drop
    I measured today and my calcium hardness was 250. I measured twice just to make sure. It had been around 350. What would cause such a drop? Poolmath says I need to add about 25lbs to get it back into range.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: CH Drop
    Rain or a leak. Really the only two ways the CH could have lowered on its own.
    Have you had either?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Casey's Avatar
    SW PA
    10,428
    Re: CH Drop
    Yes, adding water is about the only way it could lower.
    Oct 2015
    Burleson, Texas
    178
    Re: CH Drop
    Yea forgot about that. We did have a heavy rain Saturday night.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: CH Drop
    A heavy rain wouldn't do it. You would have to replace almost 1/3 of the water in the pool to have that kind of drop.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: CH Drop
    You have a new pool with significant potential issues from the "cloud" the PB created. I think the CH issue may be related. Would you please post this same question on one of your more active previous threads? This thread may be your best option due to the quality of the followers:
    Mottling
    It is important for us to know your history as you are in the process of dealing with major! issues.
    Oct 2015
    Burleson, Texas
    178
    Re: CH Drop
    The CH has been normal since the beginning. We had a heavy rain since my last normal test. The chemicals have been testing normal. I'm not sure why my post about the original start up is referenced or would have bearing to CH drop after a significant rainfall.
    May 2014
    Franklin, NC
    9,184
    Re: CH Drop
    Quote Originally Posted by Shock11 View Post
    could the rainfall have displaced over 6,000 gallons of water? It would have had to have spilled over the coping or was pumped out. Did either of those occur?
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: CH Drop
    ...I'm not sure why my post about the original start up is referenced...
    I have just been concerned about your start-up ever since the cloud appeared upon filling. I felt that your history might be important. Good luck with everything!
    30,415
    Re: CH Drop
    To get back into what range? What does Pool School say about acceptable range for CH.
    CH does not drop on it's own. Rainfall won't change it that much. What's left? Testing error is the only thing I can conceive.
    Oct 2015
    Burleson, Texas
    178
    Re: CH Drop
    Quote Originally Posted by tim5055 View Post
    It did get drained out through the overflow and into the yard. I seriously doubt I lost 6000 gallons.
    Well I test anything that is not in normal range twice to make sure that it is tested correctly. The only difference is that I used the speed stir. So the only error would be that the speed stir causes a difference in reading due to the amount the solution is mixed.
    May 2014
    Franklin, NC
    9,184
    Re: CH Drop
    If you are saying you hand stirred for the 350 result and the speedstir for the 250 result then you have your answer. It is very common for this to drop when changing from hand stirring to usin a speedstir.
    Support the site
    Oct 2015
    Katy/Texas
    411
    Re: CH Drop
    Test results will be more accurate, consistent or repeatable using the speedstir.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Oct 2015
    Burleson, Texas
    178
    Re: CH Drop
    I'm going to pick up some calcium chloride. Being that the pool has been filled for a month, should I raise to 350 or just raise slightly since it's currently 250? They haven't put the salt in yet so I'm still treating it as a bleach pool. Being that the water is 52 degrees, should I dilute in a bucket first or broadcast?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: CH Drop
    You need to post a full set of numbers. There are a lot of other factors that come into play and have a direct effect based on the CH level.
    -Brian-
    POOL BUILD
    Oct 2015
    Burleson, Texas
    178
    Re: CH Drop
    PH: 7.8
    FC: 3
    TA: 60
    CC: .5
    CH: 250
    CYA: not measured
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: CH Drop
    Your numbers are fine where they are now since they yield a CSI of -0.26.
    The decision to add calcium is going to based on the CH of your fill water, the rate of evaporation you expect to experience, and the average annual rainfall. I my area, with so little rain, we constantly fight rising calcium levels so adding calcium would only make the problem worse and require a water replacement sooner than if no calcium was added.
    Once you add salt to the pool, your CSI will drop further to -0.49 (assuming 3200 ppm and your current numbers). It would be best for you to target a pH of 7.6-7.8 and maintain the TA around 60-70.
    Use Pool Math to calculate The CSI for you. Shoot for +0.1 to -0.2
    -Brian-
    POOL BUILD
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CH Drop
    You do not need to add Calcium to your pool. Be grateful it is where it is. It will come up in time on its own.
    Essential Links:
    Oct 2015
    Burleson, Texas
    178
    Re: CH Drop
    Quote Originally Posted by Patrick_B View Post
    I thought it was the opposite. I thought that you would not want your CH to be low and pull calcium from the new plaster.
  20. Back To Top    #20
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: CH Drop
    Other factors play into the aggressiveness of the water, thats what the CSI is for. The actual calcium content in the water has surprisingly little to do with it.
    PH has the biggest effect, so keeping the pH on the higher side of things will help (in addition to requiring less acid to maintain), TA has the next biggest impact. Play with some numbers in pool math and see how the CSI changes.
    Plaster degradation occurs around -0.7 (which you are well above), and even then, its a slow process.
    Your calcium level is fine where it is now. The recommended levels are nothing more than a guideline to simplify things for those that don't use the CSI.
    -Brian-
    POOL BUILD
