Thread: How to store Stenner and tank for the winter.
    Dec 2014
    Riverside California
    482
    Now that my pool is stable at FC = 7 without running my Stenner at all for about a 2 weeks now because of way less UV and heat, wondering if I should disconnect it and just throw in some bleach when I see the FC level go down. The first thought I have is to get a 1/4" PVC plug, pull the Stenner injector/checkvalve, put in the plug with some teflon tape and just store the Stenner pump and tank somewhere out of the elements. I don' have the room in my garage for this, but could cover it with a nylon cover and bungy cord. The 5 gallons of bleach I still have in the tank probably would go down the drain with a lot of water. I also have 6 gallons of new bleach from Sams Club that I stupidly bought before I realized that winter bleach consumption is super low. Before the TFP method I just filled up my floaters with tabs when they got low.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    JoyfulNoise's Avatar
    May 2015
    13,230
    Re: How to store Stenner and tank for the winter.
    Sounds like a good idea. My SWG barely ever runs these days so I manually chlorinate which is few and far between. I see no reason to discard all that bleach if you can use it. It may not be full strength but you can still use it to manually chlorinate. If it's a little off your test kit will tell you that. Why throw it down the drain??
    Matt
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    I'm in a little different situation as my Stenner & tank are indoors (a really tall "crawl space'), but here is what I do with mine each year. When it is the end of the "bleach season I crank the Stenner up to max (mine is adjustable) and run the tank as low as it will go. I then fill the tank with water and run that through the Stenner as well to clear the bleach from the lines. It has no possibility of freezing where it is so I just let it sit for the winter.
    Why flush the bleach down the drain? Use it to bring the pool up to near shock level and hold it there until the chlorine is gone. It won't hurt anything.
    Support the site
    Jul 2015
    Central Valley CA
    1,109
    You can give the bleach to friends and neighbors for laundry, at least it will get some use before destroying whatever enzymes the department of sanitation may be using.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Dec 2014
    482
    I was going to throw the bleach in the tank down the drain, because by the time I would use it again it would probably be degraded by a fair amount. I would rather flush out the tank and rinse it than have old bleach stored in it for a few months. Same goes for the tube in the Stenner and the PVC lines, better flushed and dried for storage. Dried bleach creates salt, which I do not want in my lines or check valve/injector. The 6 gallons of Sams Club bleach can be used for toilets and other nasty things over the winter.
    May 2015
    13,230
    Well, 640oz of 6% bleach in your 38000 gal pool will raise your FC ~8ppm. Why not just dump it in your pool ? Why waste the FC?
    Matt
