Thread: What to do New water after 24 our Ph 7.7 Ta 120
    Aug 2015
    Arnhem/Netherlands
    109
    Hello yesterday i have renew my water.
    Now i have.
    I wil follow the Dichloor bleach (yesterday i have put in 8 gram of dichloor granular)
    I lowering the Ph till 7.2 and then Ta wil decraese also ??
    And then aerate till Ph 7.7 (7.8)
    And do this again and again till Ta is low enough.
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: What to do New water after 24 our Ph 7.7 Ta 120
    Yes. Maintain your pH. When it rises to 7.8, lower pH to 7.2, then pH will rise again with aeration. Repeat until your TA is 50-60 ppm. Remember that dichlor is also acidic, so each time you add dichlor, this will also lower your pH, but only a small amount. Near 0.2 pH units per 8 grams in your tub volume.
    Isolated Spa - 345 Gallons
    Aug 2015
    Arnhem/Netherlands
    109
    Thanks JVTrain.
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2015
    Arnhem/Netherlands
    109
    Delete post
    Factory is Caldera
    Above ground
    6 months old now.
