Thread: Need help locating pool supply line
    Nov 2015
    Santa rosa ca
    15
    I have a gunite pool from the 70's. Removed the coping and I am going to replace. Thought I'd replace the old supply lines too. Problem is that I dug down behind one of the supply jets and I can't find a thing. The gunite wall is about a foot thick. Did they bury the supply lines in the gunite?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Re: Need help locating pool supply line
    Could be.........BUT it has to come out to go to the equipment pad somewhere. How far down did you dig? How far out?
    Kim
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I think what you are talking about are the returns. Check this out for information Pool School - Pool Circulation System
    It is entirely possible that the return line is embedded in the gunite and may only have a single pipe running from the pool to the equipment pad.
    Is there a reason you want to replace it?
    Support the site
    Nov 2015
    Santa rosa ca
    15
    Thanks for the replies. Sorry I was away for Christmas break.
    Dug further and found it. Problem is I cracked the elbow while digging. Now broken. Ugh. Any ideas on how to fix? Pipe is buried in both side so moving the pipe would be difficult. Some of it is buried in concrete type material. Can a patch be put over the crack in the elbow?
    30,419
    Abrupt answer is "No". You'll have to dig it up and replace that elbow, I think.
    Apr 2013
    Sacramento, CA
    2,769
    First I want to reiterate what Dave said above, you can't patch an elbow. You will probably have to be a bit creative and replace the elbow.
    If you can post a clear picture of the cracked elbow we can give you some advice. Also post a picture of the whole pool and the whole equipment pad.
