Results 1 to 12 of 12
Thread: Venting a raypak heater.
    Oct 2015
    Dallas
    123
    All the pool equipment is In a small shed attached to the house. Sheds about 9 by 9 and 8 to 10 feet tall. I am having some pool people Coke out to install a raypak but they did notify me that they would not unless the shed was properly ventilated.
    from my understanding they are right.
    So to properly vent they shed, I would need a lower entry vent, a upper vent, and a exhaust for the raypak double exhaust pipe to pipe out of. Now I am confident I can chop into the side of the shed and install some vents or soffits for the air circulation. What I am not sure about is the vent for the raypak.
    i am not awefully comfortable with chopping into the shingles of the roof shed (there is no slope I can see). Is it possible to vent the raypak out the side of the shed instead of out the top? If so what's needed? If not, I'll have to find a handyman to create a roof vent.
    thanks.
    Inground Gunite/Plaster pool with spa. Estimated 31,000 gallons.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Venting a raypak heater.
    I have a similar setup (shed) as you.
    I have one roof vent, a chimney/exhaust vent for the heater and a large vent in the lower section of the door.
    Dolphin E10 Cleaning Robot.
    Oct 2015
    Dallas
    123
    Doing some more reading and apparently to sidevent I'd have to install the powervent to the raypak (which I don't want).
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    I would not side vent the unit. Go straight up thru the roof. Yes a power vent is needed if you are going to vent it not straight up or if the vent pipe has a very long run to the outside.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2015
    Dallas
    123
    Ok I'm reading more up on this. I need someone to doublecheck my logic here because I don't quite understand terminology.
    To install the heater in an enclosed space, I need to vent it to the roof. For the raypak 406A/407A, I would need a indoor stack kit (009841) or an outdoor stack kit (009837)? I think i need a indoor stack kit which includes a draft hood, adapter, mounting bracket, screws and instructions. Are these instructions listed online anywhere to read?
    I am assuming the indoor stack kit does directly onto the raypak heater (add panel, attach hose, clip). After that, I would attach a 3 or 4 inch dual wall (type b vent) vent pipe? In the roof, what type of vent would I put up there (I think I know which actually).
    banditig's Avatar
    Sep 2015
    Ohio
    466
    humm, they look almost the same except outdoor kit has a top panel cover and a painted draft hood. Yes use type b vent, but I think its much larger than 3 or 4 inch.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Oct 2015
    Dallas
    123
    I can't find a 9 inch b vent pipe.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Quote Originally Posted by Pemolis View Post
    9" is an odd size. You'd have better luck with 8" or 10". Give Raypak a call and see if 8" is suitable for your application. Most similar gas appliances use 8" B vent or 4" Category III vent pipe when used in pressurized applications.
    Be prepared to pay...That vent pipe gets very expensive above 4" diameter
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Oct 2015
    Dallas
    123
    Just spoke with a pool installer regarding that flue and they also say a 9 inch one.
    problem is finding someone to install the dang thing.
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    A call to a HVAC person should do the trick. Of course, they might not want to take on the liability maybe. Some places are funny about that. I know I am.
    Paul
    Oct 2015
    Dallas
    123
    Have a handyman coming over to chop out two vents and a roof vent for the water heater.
    Didn't think protecting your equipment would be such a pain
    Had a installer come over today (handyman didn't show), who gave me some ideas about venting out the side oddly enough. I'm still aiming at doing the roof though.
    Were planning on doing a bit of a rework of the plumbing in the cabinet as the filter is pretty much where the heater should be (it'll be a total replumb in the cabinet).
