Thread: When to start with boric acid
    Aug 2015
    Arnhem/Netherlands
    109
    Hello, i have fill today my spa with new water, and starting with Dichloor 8 gram til i have (30/40 CYA).
    But when is the time to start boric acid.
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    JoyfulNoise's Avatar
    May 2015
    13,217
    Re: When to start with boric acid
    You should only add your borates once you've gotten your TA lowered to 50ppm. Adding them before that will make it much harder to lower your TA as the borates will buffer pH changes.
    Matt
