Thread: Covering your equipment
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    Is it beneficial or necessary to shade your pool equipment? ie. pumps, filter housing etc.
    I was wondering if erecting a shade structure over my equipment would prolong the life of the exterior of the equipment.
    Any thoughts would be appreciated.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    30,403
    Re: Covering your equipment
    The enemies of anything mechanical are sun, rain and dirt. Anything you do to minimize that exposure is generally beneficial.
    Feb 2008
    Denton, TX
    5,061
    Just make sure that if you do construct a cover or housing for your pump and filter setup, that you:
    1). Allow for ventilation. Pool pumps can generate a goodly amount of heat on their own.
    2.) Construct it so that you are still permitted good access to things easily. Take it from a guy who build a great housing for this equipment, only to discover later that I couldn't lift my filter housing free to clean the filters.
    chris4150's Avatar
    Apr 2009
    180
    I was thinking about mounting a cleat on my brick wall above the equipment, attaching outdoor patio solar screening to the cleat, and attaching an aluminum tube to the front end of the material that could be extended forward and proped up with two aluminum tubed legs. Hopefully, readers of this post have a visual of what Im describing.
    Mar 2007
    Coastalish 'down easter'
    4,160
    I think I 'see' what you're saying and it sounds like a good way to help protect and prolong the equipment
    p.s. your equipment says ''thank you for thinking about us "
    Luv& Luk
    -Ted
    chris4150's Avatar
    Apr 2009
    180
    Yep, each day that I go by my equipment I state to myself, "it sure would be nice to provide cover for this stuff"
