Thread: Using saltwater in a normal hot tub?
    Nov 2015
    Montana
    12
    I currently own a "saltwater" hot tub it has the ACE saltwater sanitizing system in it.....
    Currently the ace saltwater system is being dysfunctional and is "offline" and making my a bit grumpy....
    so right now I am adding chlorine manually and running it like a normal hot tub.
    Is it ok to still have a 1500-2000 ppm of salt in the water??
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Using saltwater in a normal hot tub?
    Yes, no problem at all.
