Results 1 to 10 of 10
Thread: To cover or not to cover, that is the question :)
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    As of right now, (permit stage) we don't have plans for a cover. We have a full sun backyard with no landscape, however, both next door neighbors have trees. We never have to rake and historically get few leaves or debris in the yard.
    What are the pros and cons to covering?
    If you don't cover, do you still winterize your pumps, etc or do you run them year round?
    we live in the Tulsa area. Winters can be cold with snow and ice but typically are not prolonged more than a week or so at a time. Currently we have spring-like weather. Our worst winter weather is usually Jan Feb March.
    If you do cover, what kind do you use? Would you recommend it?
    Thanks for your input!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Jun 2014
    15,255
    Re: To cover or not to cover, that is the question :)
    Congrats on the new pool! Lots of pros & cons on the forum about covers. Generally speaking, the biggest advantage for having a cover in the winter is to keep leaves and organic debris from falling into the water, reducing the amount of cleaning required later. Covers are favored by many in the summer to help reduce sun/UV effects on the chlorine as well, saving a bit on FC consumption. A little south of you here in TX, Jan/Feb are our coldest months as well. No hard freezes like up north, just a few mornings of freeze warnings that usually go away by mid-day. On those days, we leave the pump running to keep water moving through the pipes as a precautionary measure, but other than that pump use slows-down considerably. In my region, I do not winterize (shut-down, disconnect pump, etc) my pool each year. I just run the pump occasionally, clear the skimmer, and check chemicals once in a while as needed since the colder water really doesn't require much chemical attention. Some folks swear by covers, others are just happy without. I suspect others will reply with more specifics - hopefully someone who lives in your local area. Good luck!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Quote Originally Posted by Texas Splash View Post
    Thanks, Pat!
    Denise-TFP Guide
    JoyfulNoise's Avatar
    May 2015
    13,254
    I did not use a cover for the last three seasons. As such, my CH is quite high now (~800ppm) due to constant use of city fill water (CH ~ 280-350ppm). So if you live in a dry area with low rainfall, no cover will mean ever increasing CH if you have hard fill water.
    I plan to purchase a reflective bubble cover next year and try to use it as regularly as I can. I want to see what impact I'll have on FC demand and I want to lower my water usage as Tucson city water gets very expensive in the summer.
    If you have a freeform pool design, using a cover can be a real PITA but there are roller methods out there to help (available on Amazon and DIY concepts here on TFP).
    Matt
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    In the Tulsa area we get a decent amount of rainfall/precipitation through the fall/winter/spring. It can get pretty dry during the summer though. Is it better to keep all of that precipitation out of the pool?
    Our design is rectangular in shape, so maybe a little less PITA...
    Denise-TFP Guide
    May 2015
    13,254
    Quote Originally Posted by Nursenini View Post
    Actually, rain water is excellent for pool fill. Low pH, no TA or CH. So, in moderation, it can really help keep your water balanced. And the best part is, it's free!!
    Yes, a rectangular shape helps a lot. If you have the money, you can get a high quality reel for your pool cover and that will make using one A LOT easier.
    A good quality bubble cover will also help you retain water heat as well. So I think, in the end, you should seriously consider a cover. More upsides for you than downsides.
    Matt
    Aug 2013
    Oklahoma City, OK
    140
    I own a loop-loc cover that I have not used the past 3 winters. I just run the pump as needed on cold nights. Leaves can be a bit of a pain but much easier to just let it run on cold nights and still get to look at a pretty pool year round.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    That's great info about the rain water, the reel and the bubble cover, Matt. We may very well be tapped out this first year and not be able to afford a cover even if we decide we want one.
    Quote Originally Posted by Tanner M View Post
    Do you have any water features? If so, do you winterize those lines or do you just run everything? I think OKC runs a little warmer than we do up here in the Tulsa area, but not by much.
    Denise-TFP Guide
    May 2015
    13,254
    TFP Expert mas985 (Mark) has an awesome little tutorial thread on a DIY solar roller cover reel made out of PVC pipe and automotive clips. See it HERE. It can at least save you the cost of buying an expensive reel.
    Matt
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Thank you! I'll check it out!
    Denise-TFP Guide
