Thread: Solar Cover Solution?
    Sep 2007
    High Point, N.C.
    43
    I have been perplexed for some time on how to use a solar cover with my pool. Think of it's shape as a triangle with rounded corners. The base of the triangle is 25' long. The rounded top of the triangle is 12' across. The length is 27'.
    I have a heat pump and have read on troublefree.com of the importance of preventing night time heat loss...that is the goal. I doubt there is a reel available long enough for the 25' end, so I am asking for any helpful suggestions, please, for how to easily apply and remove a cover for my pool. Also if you have any links to send for discussions of the type (quality) of solar cover you would recommend it would be appreciated.
    20,000gal, inground, vinyl liner, 1.5hp Hayward Superpump, Hayward sand filter, Heat Pump, CircuPool SWG, BBB w/o Borax, one skimmer, Caretaker floor popups, two return jets at stairs, waterfall.
    38,526
    Re: Solar Cover Solution?
    You could try a shorter real and fold the cover before rolling up. Or just cut it into pieces and either roll up the pieces or just pull off and pull them up manually.
    JoyfulNoise's Avatar
    May 2015
    13,255
    User mas985 (Mark) has a very nice thread demonstrating how to build manual rolls for covers that are cut for freeform pool shapes. I plan to start using a cover next year and I'm going to implement Mark's very helpful solution.
    Matt
    Apr 2013
    Sacramento, CA
    2,769
    Mark's solution is based on the Solar Roller.
    ww.amazon.com/Solar-Roller-EXTENDS-COVER-LIFE/dp/B00IV3QKQG/ref=sr_1_5?ie=UTF8&qid=1450068479&sr=8-5&keywords=pool+cover+roller
    I like my Solar Roller But you probably have to split your cover in two because it does not work well for large areas.
