Results 1 to 10 of 10
Thread: Is this set up too much ?
    Hi guys, my first post here and completely new to pools.
    I have a 16' round x 4' deep intex above ground pool which I have just fitted and set up.
    I found the std 1500gph pump to be ok if the pool was clean but if you wanted to hoover the pool it was a bit lacking in power, also the filter gets blocked every few minutes so you spend more time cleaning the filter than you do the pool. The pool had been collecting water and debris over the winter whilst I built the decking around it.
    I picked up a used 32" x 16" doughboy sandfilter and 3/4hp pump, works really well, but a few questions if I may.
    Is the pump far to big for what I need and if so will it do any damage ?
    How long should I run the pump for basis 5000 gallons, water being correct and no debris ?
    How often should the sand in the filter be changed ? ( I gave it a good backwash)
    I note in the Doughboy handbook NOT to put chrlorine pucks in the skimmer for potential damage to the pump is this correct as I have never heard of that before ?
    Many thanks
    Paul
    Paul Jennings
    Kent UK
    16ft x 4ft Intex above ground pool, 32" x 16" Doughboy sandfilter, Doughboy 3/4hp pump, 9kw Elecro heater, 11/2" pipework.
    Paul Jennings .....Kent ... UK (cold or colder)
    16ft x 4ft Intex 5000 gallon above ground pool, 32" x 16" Doughboy sandfilter, Doughboy 3/4hp pump, 9kw Elecro heater, 11/2" pipework, 400 micron bubble cover.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Is this set up too much ?
    Correct you don't want to put pucks in the skimmer. Big no-no. When the pump is off, and the pucks sit there, the concentrated water in the skimmer/pump area becomes very low in PH and very high in chlorine...it can cause the parts to become brittle if they are plastic and corrosive/destructive to other pump parts.
    As for the pump set up....I'm no expert on that - someone will chime in.
    Thanks, that would sort of make sense as the pump is plastic construction. Luckily I have had the pump on pretty much full time so far to chlorinate the pool etc.
    Regarding the pump the reason I am a little unsure is because there seems to be 2 ways to size a pump, GPH (simple enough) and HP which I cant find a conversion table for.
    With time running I was told by the local poolstore that any pump needs to run for minimum of 9 hours per day, but sure I read on here that the water needs circulating only once a day, so 2500 gph pump needs to be on just 2 hours a day under normal circumstances with a 5000 gallon pool etc etc
    Regards
    Paul
    Shorter run times are fine if you have a large pump.
    If you know the exact model number of the 3/4 HP pump we can make a good guess at it's GPH.
    Hi Jason, many thanks for the guidance.
    Its a fairly old pump 2001 I think, model 0-1065405 3/4hp 930 watts.
    Also what are your thoughts on changing the sand ? do I need to do that ? it all seems fine although I do need a new pressure gauge.
    Regards
    Paul
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by Pool Jennings
    Regards
    Paul
    That looks like info off the motor. Any numbers visible on the wet end itself?
    The sand should be fine. The industry will tell you it needs to be done every 3-5 years (is the pool even that old?), but if well cared for it usually lasts much longer than that.
    Guessing a little, based on the 930 watts, I expect that pump is somewhere around 25 to 30 GPM, or 1500 to 1800 GPH.
    Quote Originally Posted by spishex
    Regards
    Paul
    I assume you mean the impellar end, will have to look when I get home.
    No the pool is new but was dissapointed with the std pump and filter in particular.
    Sandfilter appears to work fine, pool is very clear, hoover works well even when on filter without any visible dirt returning to the pool, am assuming that the filter is 2001 same as pump, as this is the UK we probably got that here circa 2002 so could pottentially be 7 or so years of use, I will keep a look at and change sand if any sign of debris or pressure build up.
    Thanks
    The original was allegedly rated at 1500gph, this has a lot more suck and blow than that, Have not created a whirlepool or a spa jet scenario but just wanted to check I would do no damage with over pumping as it were.
    If it was say 2000gph for simplicity, what would you say the normal run time should be ? and again assume end of the day or night running is best ?
    Many thanks
    A good starting point for pump runtime is to pump as much water as you have in your pool each day. A 5,000 gallon pool and a 2,000 GPH pump would suggest a 2 1/2 hour pump run time (with a clean filter). Your ideal run time might be a little shorter or longer than that, depending. I would start with 3 hours and then tweak it from there.
    Exactly when during the day you run the pump isn't all that critical. Running the pump in the evening is fine.
