Results 1 to 9 of 9
Thread: Second option on balancing water
    Jul 2015
    Poway, CA
    58
    So, I think I got it but I want a second option. I have used all of the charts and pool math. Should I have my CYA at 40? Thanks for the help!
    FC 4
    CC 0
    CH 325
    CYA 30
    TA 110
    pH 7.6
    Temp 60F
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    Casey's Avatar
    SW PA
    10,428
    Re: Second option on balancing water
    Lookin good! How's the water look?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You numbers look ok. Whether or not a person should increase the CYA is determined largely on how much FC is being consumed over the course of time.
    The largest factor regarding the CYA level, is how much UV you recieve in your area. UV eats up FC, CYA helps slow that process down. People in the lower latitudes across the US generally do increase their CYA up to as high as 50. The recommended levels chart for Non SWG is 30-50 just for this reason.
    Quote Originally Posted by Imracerx View Post
    FC 4
    CC 0
    CH 325
    CYA 30
    TA 110
    pH 7.6
    Temp 60F
    Divin Dave,
    Jul 2015
    Poway, CA
    58
    Crystal clear
    Quote Originally Posted by Divin Dave View Post
    I am in San Diego. So a CYA of 50 would be better correct?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Crystal clear
    Yes. But in the off-season, you'll hardly lose any FC so there's no hurry. With any luck, the El Nino will dilute the pool this year and you'll have to raise it in the spring.
    JoyfulNoise's Avatar
    May 2015
    13,192
    My only suggestion is that your TA looks a little on the high side. It will probably be ok for now and there's no rush to "fix" it but in the summer you may see your pH rise a lot. If your TA is still above 100ppm, then you might want to consider lowering it as high TA can lead to fast pH rise. Again, not something to go out a fix right now, just something to keep an eye on.
    What is the quality of your fill water (pH, TA, CH)?
    Matt
    Jul 2015
    Poway, CA
    58
    What level is ideal for TA?
    May 2015
    13,192
    Whatever value gives you the most stable pH. For some people (like me), it would have to be ridiculously low so that's not practical. I try to keep my TA below 70ppm and supplement my pool with 50ppm borates. That makes my pH very stable.
    Matt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Getting your TA adjusted just right is part of the learning curve. TA buffers the pH. So, keep a record of how quickly your TA rises. If its pretty quick and you have to add Muriatic Acid more than often enough to suit you to lower the pH, then you can lower the TA to help buffer that.
    It takes time to lower and then monitor it for a while, so it takes a good bit of time to get it where things become stable. So patience is key.
    Divin Dave,
