Thread: Pool Cleaner in-hose filter clogged
    Feb 2015
    The Woodlands TX
    46
    I have a polaris pressure side cleaner that cleans well enough when everything is clean. The big problem is that my in-hose filter screen clogs extremely quickly. Often times, the filter clogs within one day of cleaning it. Is this common? Is it an indication that something else in the filtering system is not working well?
    On a related note, I have read many posts about robotic cleaners. One thing that is encouraging about the Dolphin Nautilus is the claim that it picks up fine particles well, which is the junk that is clogging my filter screen. A drawback seems to be that it does not have a large capacity for leaves. My pool gets a lot of leaves, especially in the fall, though I can help this issue by using my net.
    I'm looking for some advice and other experiences. Thanks.
    12,000, IG 1992, 4.5' center/3' each end, Pentair FNS-60 DE Filter (2015)
    PebbleSheen installed 2015
    Pentair Superflo VS installed May 2016
    TF-100 Test Kit
    Dolphin Nautilus Plus Robot
    30,403
    Re: Pool Cleaner in-hose filter clogged
    Your polaris is doing what it is supposed to do. It's your water chemistry that is your issue.
    I suggest you start by reading "The ABC's of Pool Water Chemistry" up in Pool School. You will probably need to SLAM your pool but you need to get a good grip of what is causing your problem (probably algae) so you can go forward
