Thread: General Plumbing Question
    Jun 2014
    St. Louis, MO
    6
    Just want to say that I've enjoyed the site over my few years as a new pool owner. You guys have saved me a ton of money. I have a general question about plumbing. I have a 30,000 gallon vinyl lined pool that is around 20 years old. When I closed the pool I noticed that my ball lock valve for the main drain and shallow end skimmer were shot. The shallow skimmer is stuck in open and the main drain leaks. I got lazy and paid someone to replace them. It is plumbed with 1 1/2 inch PVC. I looked at it today when I got home. Looks like they took the easy way and just cut the pipe at the 90 degree elbows where they came out of the ground and then inserted a new smaller pipe inside of the existing pipe (presumably 1 inch PVC) and used an adapter to bring it back to 1 1/2 for the valves. They did this probably because they would have had to dig a little to do it all in 1 1/2 inch. Is down sizing the pipe for this short segment going to cause any issues. Thank for all the help over the years. If it makes a difference I have a 1 HP single speed pump, a 300 lbs sand filter, gas heater and salt water generator.
    Jason
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: General Plumbing Question
    I don't think so. My equipment at my current home is like this (reversed though) and last home is like yours.
    Never had any problems.
    Dolphin E10 Cleaning Robot.
    Jun 2014
    St. Louis, MO
    6
    Thanks for the reply. I figured it probably wouldn't cause too much of an issue.
    30,000 gallon L-shaped, vinyl liner. 1 hp Hayward super pump, 300 lbs Hayward sand filter, Aqualine gold SWG and Jandy Lite2 gas heater.
