Raising CY
Wouldn't the test be accurate the next day?
Maybe. I takes mine about 3 days. We say it can take up to a week because others on the forum have reported that.
By far the best way to measure CYA is to calculate the dose. If your pool is XXX gallons and you are sure of that, simply use pool math to Bring CYA to your desired amount. Then dose accordingly and you are done. You can double check yourself with the test but it should be on the money by calculation.
