Thread: Raising CY
    Sep 2015
    SW Florida
    16
    Raising CY
    I see posts that it takes a week for stabilizer to show in tests. The stabilizer I use is dissolved in less than 8 hours. Wouldn't the test be accurate the next day? I run the pump for 24 hours as well after I add stabilizer.
    In ground shotcrete 9,500 gal.w/pebbletec, Pentair Intelliflo VS Pump, Pentair Intellichlor IC 40,
    Pentair cartridge filter, Built Right heat pump, TF-100
    30,408
    Re: Raising CY
    Maybe. I takes mine about 3 days. We say it can take up to a week because others on the forum have reported that.
    By far the best way to measure CYA is to calculate the dose. If your pool is XXX gallons and you are sure of that, simply use pool math to Bring CYA to your desired amount. Then dose accordingly and you are done. You can double check yourself with the test but it should be on the money by calculation.
    Sep 2015
    SW Florida
    16
    Re: Raising CY
    Thanks, I did use pool math. My pool is free form so how much it holds is a best guess by the builder + or - 500 gals. I'll wait a few days to recheck.
    30,408
    Re: Raising CY
    so that would give you roughly a 5% error.....that's perfectly adequate.
    Sep 2015
    SW Florida
    16
    Re: Raising CY
    Thank you
