Thread: No pool pressure
    No pool pressure
    Have a 10k gallon pool in AZ that was fine over summer. Pressure was at zero so presumed it was just time to clean DE filter which I did but pressure is still at zero. My question is what should happen when I take the skimmer basket out and turn the pump on? Nothing seems to happen and when I turn it off, the motor spits a little water out into the skimmer. Not sure what I am supposed to see?
    30,426
    Re: No pool pressure
    Nothing will happen. You create a suction side air leak when you remove the lid and the pump can not prime,
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Dirty DE filter would raise the pressure not move it to zero. You seem to have a no flow scenario. Is water coming out of the jets? Is the pump basket full of water before and after you turn on the pump?
    Do you mean skimmer basket or pump basket? Unless one or both are completely clogged, neither should markedly affect pressure.
    You may have a clogged impeller - turn off power to the pump (make sure it's off) then take the pump basket lid off. You should be able to carefully reach a finger into the pump basket, toward the pump and feel the impeller. There should not be any debris on it. It doesn't to much junk to disrupt the impeller's ability to move water.
    If you have water in the pump basket and water coming out of the returns - your gauge is bad. Just replace it. TFT sells a nice one at a very reasonable price.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    The big question is: when everything is put together and you turn the pump on, is there flow in the skimmer well and coming out the return jets. If so, you have a bad gauge.
    If the scenario is something else, describe it in better detail. please.
