Results 1 to 8 of 8
Thread: Muriatic Okay With DE and CYA?
    Apr 2015
    Pasadena, CA
    56
    I have a vinyl deck box out near my pool where I keep my Muriatic acid. It stays locked so the kids, pets and critters don't get into it. Just wondering if it's safe to also store CYA and diatomaceous earth in the same box? I've read some things are a no no, so just checking. Thanks.
    22,000 gallon IG plaster pool, raised spa w/spillover, variable speed EcoStar pump, natural gas heater, 60 SF DE filter, SWG (all Hayward), AquaLogic automated controller, Kreepy Krawly, TF-100 Test Kit
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Muriatic Okay With DE and CYA?
    i don't believe MA bottles vent, like chlorine, but not sure.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Oct 2015
    Katy/Texas
    411
    My MA and bleach bottles have seals under the cap. So it is not possible for them to vent before the first time you open them.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jan 2014
    Buckeye AZ
    807
    mine too but the seal has a pinhole in it....
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    JoyfulNoise's Avatar
    May 2015
    13,175
    You can store acid with CYA and DE. There is no problem there. Bleach and acid MUST be stored separately. Bleach should NEVER be stored outdoors nor stockpiled for long periods of time as it degrades within months. It would be best to make sure your deck boxes are properly vented or else acid vapors can build up and be quite irritating.
    Matt
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Make very sure that there is nothing in there that acid fumes can corrode or ruin.
    chiefwej
    Apr 2015
    Pasadena, CA
    56
    Thx everyone! Yes the box is vented just by bad design. It's not airtight.
    Mar 2007
    San Rafael, CA USA
    12,082
    Full-strength Muriatic Acid (31.45% Hydrochloric Acid) has a high vapor pressure at higher temperatures. This paper and page 2-76 in this paper show that the vapor pressure of the acid at 40C (104F) is about 81 mm Hg or about one-tenth of an atmosphere pressure. Water vapor pressure adds another 18 mm Hg on top of that. So some bottles of Muriatic Acid have vented caps while those that are sealed need to withstand these or higher pressures.
    Normally the "safer" Muriatic Acid that is < 25% or the half-strength that is 15-16% is in sealed bottles since the pressure is not nearly as high. The acid fumes significantly less. The half-strength has roughly 1/280th the vapor pressure from the acid while even 25% has 1/14th the vapor pressure from the acid.
