Thread: Chlorine tabs
    Nov 2015
    Ok ok
    822
    Chlorine tabs
    After reading and understanding that using tablets can eventually build up too much stabilizer, do they sell chlorine tablets that are stabilizer free? I had a pool guy tell me today that they recommend a chlorine in line injector, that used tablets. I was concerned about building up too much stabilizer. Still leaning toward a SWG. Still have to replaster pool prior to doing anything, but wanted to be prepared upfront. Thx
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Apr 2013
    Sacramento, CA
    2,769
    Re: Chlorine tabs
    Granular chlorine, chlorine tabs or any other form of dry chlorine comes with something added that may result in a problem. Trichlor tabs have a chemical consistency such that one of the problems is adding additional stabilizer or CYA to your pool. Some is a good thing, too much reduces the effectiveness of the chlorine. Cal Hypos tabs add calcium which can cause deposits on the pool surfaces. Inline injectors take tabs.
    SWG is one of the better ways to make your pool less of a chore.
    Donldson's Avatar
    NW Ohio
    2,892
    Re: Chlorine tabs
    Chlorine is naturally a gas, it must be combined with something to be a liquid or solid. For liquid that something is just salt and water. For solid the options are cyanuric acid, calcium, or lithium.
    Trichlor is the only option that makes a solid that is usable in any form other than granular. That is why almost all pucks are made of trichlor. There are some options that use binders to make sticks out of calcium-hypochlorite, but these need special feeders and can not be mixed with trichlor sticks. In either case a buildup of CYA or calcium can lead to problems.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Chlorine tabs
    For automated chlorination, your choices for what's recommended here and are the most trouble free, it's either a SWG or a stenner pump/ liquid chlorine injection system . SWG is the most popular because it's the easiest. Liquid chlorine injection systems such as the Liquidator are also somewhat common for TFP users but more of a niche percentage than SWG. Tablet feeders can be nice for temporary use in a manually chlorinated pool such as during a vacation, but long term use will lead to issues that will necessitate draining and refilling.
    Isolated Spa - 345 Gallons
    Nov 2015
    Ok ok
    822
    Re: Chlorine tabs
    As usual, your help is very much appreciated. Thank you for the replies and clarification.
