Thread: Barracuda cleaner and pressure drop
    Nov 2015
    Melbourne, VIC, Australia
    170
    I have a *very* old Barracuda cleaner that really needs to be replaced, but I'm stuck with it for now.
    It came with the pool when I bought the house 5 years ago and was old then.
    Pool shop guy tells me that they used to be the best cleaners you could get, but I'm leaning towards a robotic one now, but that's another topic.
    Current problem is that when I connect the Barracuda it will run for a few seconds and then stop. When everything is fine, pressure sits around 80 kPa / 12 psi.
    When I hook up the cleaner now, this drops by about half. It doesn't usually do that.
    I've checked the diaphragm as that's a usual point of failure and I'm currently on my 4th or 5th one in 5 years - its a yearly consumable. This time there are no obvious splits, but there is a weak spot that is very thin and looks like its about to go. I'm pretty sure this is probably my problem, but I guess I'm looking for any other tips before I trot off the pool shop again.
    39,000 litre (10,000 US gallons) IG vinyl salt water, Waterco S600 Sand filter, Zodiac Tri Chlorinator, Hurlcon E Series 230 pump, Taylors K-2006C Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Barracuda cleaner and pressure drop
    With your experience on these, I'd say you've figured it out. Since you are leaning that way, I'd say jump aboard, and go with a good robot straight away. You'll never regret it, or have to fool with this issue any longer.
    Essential Links:
    Nov 2015
    170
    Thanks for the confirmation.
    Need to start saving my pennies for a good robot. I haven't really researched them much, but I do believe that it is actually worth spnding a bit more and getting a good one.
