Results 1 to 10 of 10
Thread: Storage of used pucks
    Dec 2015
    Cypress, Texas
    57
    When the pool was turned over to me I removed about 6 pucks from the inline feeder. I decided to keep them to use when I am away from the house for a few days. I put them in a Ziploc bag in the garage. The smell in the garage is getting overwhelming.
    Can I store them in the inline feeder if I turn it off? Or should I just throw them away and buy more when I need them?
    16,388 gallons, IG, Pebble Sheen, Pentair Clean & Clear Plus cartridge filter, Pentair Whisperflow Pump, August 2015, Taylor K-2006, spa
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Storage of used pucks
    Did you let them dry out REAL good before you bagged them up? That is the secret to saving them.
    Kim
    Dec 2015
    Cypress, Texas
    57
    No I did not
    Jul 2012
    Tallahassee, FL
    30,585
    So you know what to do..........sit them out in the sun on edge if possible and let them dry out REAL good.
    Kim
    38,475
    Just careful where you set them as they could discolor it.
    Dec 2015
    Cypress, Texas
    57
    Thnx for the tips
    JoyfulNoise's Avatar
    May 2015
    13,247
    The pucks are emitting chlorine gas which is not only corrosive to anything metal in your garage but is toxic. Wet trichlor pucks should never be stored in a sealed container like a plastic bag because not only will they build up vapors to possibly dangerous levels (you could be overwhelmed by the vapors) but they can also start to oxidize the plastic which is a potential fire hazard. Calcium hypochlorite is the most dangerous solid chlorine product as it can cause dangerously fast oxidation of other chemicals around it.
    You need to remove those pucks from the garage and either put them in your pool water or dispose of them properly. You are talking about saving ~$12 worth of trichlor while potentially costing yourself hundreds of dollars in damage from metal corrosion or worse, a fire that could cause serious property damage.
    In contrast, dry, unused trichlor tablets can be stored in their original containers because they emit much less fumes from being desiccated.
    Matt
    Aug 2014
    Northern IL
    4,615
    I vote pitch 'em, but dry them out first so you don't cause damage at the dump.
    Many places have drop-off centers for household hazardous waste.
    Household Hazardous Waste: A Guide for Texans - TCEQ - www.tceq.texas.gov
    Support the site
    Dec 2015
    Cypress, Texas
    57
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Good point, I will get rid of them.
