Results 1 to 18 of 18
Thread: Best Salt Generator System
    Dec 2015
    Colleyville/Texas
    4
    A am in the process of switching my pool from a regular chlorine pool to a salt pool. Does anyone have any suggestions as to which manufacturer makes the best system. I am considering Jandy, Pentair, and Hayward. Thanks for any help.
    Jan 2015
    Maritimes
    56
    Re: Best Salt Generator System
    Personally, I wouldn't touch anything but Aqua rite for residential.
    30,432
    Welcome to the forum. Impossible to answer....who makes the best car? As always, it depends.
    22,553
    As Dave (the other Dave) said, it's pretty impossible to answer that specifically. They all make good units, and sometimes they make a bad one.
    The best thing you can do is find out which mfg. has the best service and parts near you. Also be sure to buy a unit big enough for your pool. We recommend sizing the unit 1½ to 3 times the size of your pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    If you have automation then stay with the same brand. 3+ years with the Pentair IC40 have been great. I wouldn't hesitate to buy another one.
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    I like my Aqua Rite that was installed in 2004.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I can't remember which one it is off hand, but one of the major brands (Pentair?) only allows adjustment in course 10% increments unless you also have their automation system.
    DFW, TX
    24,517
    It is Pentair that only allows 20% increments without automation. Mine is on a timer, so dialing in the percentage and the number of hours on it is not an issue to maintain the correct level of FC.
    Jan 2015
    Maritimes
    56
    Not all make great units, do your due diligence.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    For what it's worth I plan on replacing my Compupool system with Aquarite when it fully dies. It seems all units have their issues. The Aquarite have a current limiter issue that is know and is an relatively easy fix. It's a $5 part. It seems more of an issue where there's lots of power-surges/lighting.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    They all have the plus and minus I suppose. All in all though, all three that you mentioned enjoy a pretty good reputation.
    The Pentair has all of the manual controls built into the cell itself, so a cell replacement is considerably more expensive than a Hayward one.
    Hayward is pretty good unit, I dont know of any minuses except that the Current Limiter is subject to burn up. Its an easy 10 dollar DIY fix though, so this should not steer you away from one.
    I dont know anything about any of the other makers, so maybe someone will chime in on that.
    I fully concur with Isaac, get a unit rated for at least 1.5x your pool volume. Prefereably even higher. The bigger the cell is, the less wear and tear on it to produce x amount of chlorine. So, larger cells should last longer.
    Divin Dave,
    Are you looking to add automation? What are the specifics of your system?
    In general, I would consider Hayward, Jandy, AutoPilot and Pentair, in that order.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,265
    My beef with Jandy is that the largest Aquapure cells top out at 1.4lbs of chlorine per day. With Hayward and Pentair you can get more output for about the same money. What bothers me about Hayward's cell is that they must know that the current limiter is their achilles heel and yet, in all these years, they've never bothered to change their system design to fix it. So you have to ask - why would a world-class manufacturer of pool and spa equipment allow a known design flaw to persist when other manufacturer's cells do not have this problem? To me, that's a big red flag. And yes, Pentair's cell is limited to only 20% increments of output when you use it stand-alone outside of a Pentair automation panel. That's a bit ridiculous and they could change that if they wanted to.
    One thing to keep in mind is to check warranties. Often times, pool equipment manufacturers will severely limit their warranties when a person buys their equipment and installs it themselves. Pentair and Jandy have had some issues in this area where they have told customers that, because they self-installed their equipment, the warranty was only good for 60-days. So it's always best to call the manufacturer directly (even if you're going to buy it on Amazon or online retail) and ask them what their warranty policy is for self-installed equipment.
    Matt
    My understanding is that the newest AquaRite addresses the current limiter issue by using a relay to take it out of the circuit after a few seconds of startup.
    Support the site
    Jan 2012
    340
    James is correct. A relay that bypasses the current limiter has been incorporated into the design of the GLX-PCB-RITE board.
    Hayward has the best warranty and is the simplest (IMO) of the big 3. I would not hesitate for a second to install one, but as others have said, go as big as your wallet will allow.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Mar 2015
    New Orleans, LA
    81
    Jandy Fusion soft. Cells cheaper to replace, easy to clean and inspect. You can use a mineral cartridge if you want to. If you get a pro to install you get 3 year warranty. All systems should be wired to only come on when filter pump is on.
    Jun 2011
    Long Beach, CA
    2,790
    Quote Originally Posted by ConradM View Post
    We never recommend running a mineral cartridge as it is not needed and can lead to staining the pool surface.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have had an AquaRite system for over 10 years now. The cell gave me over seven years of chlorine before needing replacement. Cost of a new cell was about $400, making my chlorine cost less than $60 per year. The inflow resistor you hear about did fail at nine years, but a $2.50 part and 15 minutes with a soldering iron put that right again.
    If the whole system blew up tomorrow, I would buy a new one just like it.
    You can find an AquaRite AQR15 with the T-15 (40k rated) cell for less than $1,000. When you need a replacement cell they are under $400. I wouldn't buy anything else, but maybe my experiance makes my a little prejudice.
    chiefwej
