Thread: Rebar or mesh?
    Sep 2015
    Roseville, Ca
    16
    Rebar or mesh?
    I have a freeform pool install underway; they did deck forming
    the other day. Concrete pour next week.
    No rebar; they use mesh. I am installing 480 square feet perimeter.
    It extends 5ft out in most areas from water line but 6ft in one area
    near the middle.
    Do I want or need rebar and is it worth the extra cost to me?
    It was not stipulated in the contract.
    thank you
    Tom
    TomCa - IG, gunite, Freeform, 30 x 17, raised beam wall w/ledgestone and flagstone cap, 3ft spill, radiant fusion blue frost, 480sqft concrete decking. SWG filtration, 2 returns, 1 skimmer. 2" & 2.5"PVC . JEP15 Jandy ePump 1.5hp Variable Speed, AquaLink PDA P4 Pool Control , SAVI-MELODY100-J Nexxus 14W 12V Pool Light X 2, J Series, Polaris - 360 Cleaner, Model F1B.
    30,421
    Re: Rebar or mesh?
    What does your PB say? He has to warrant the structure so I would get his opinion.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Rebar or mesh?
    Is your question about the deck or the pool? Pool should have rebar and mesh is fine for the deck. Definitely inquire with your PB with any concerns.
    Jul 2015
    Central Valley CA
    1,108
    Re: Rebar or mesh?
    If I recall correctly even mesh for decking should be bonded though. If I recall correctly any concrete within 3ft of the pool that has metal reinforcing of any type has to be bonded. I am not a contractor though I would check with the city before the pour to be safe.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    JoyfulNoise's Avatar
    May 2015
    13,210
    Rebar or mesh?
    The choice between rebar and mesh comes down to cost and load requirements. Obviously a concrete pool shell needs to handle a significant load from the hydrostatic pressure of the water in the pool. Therefore you use the correct size rebar and pay for proper forming and installation.
    A pool deck, in comparison, sees minimal loading and therefore does not really need the added reinforcement from rebar. However, you want to minimize cracking that will occur from thermal expansion and/or soil shifting. So prefabricated steel mesh is a cheap alternative that adds sufficient stress to the concrete to keep it from cracking. Using rebar would be a very expensive alternative and far beyond the necessary mechanical requirements of the deck.
    And yes, any metal mesh within 3 feet of the pool shell should be bonded to the pool structure.
    Matt
    Jun 2011
    Long Beach, CA
    2,788
    Re: Rebar or mesh?
    Mesh should be fine for the deck. Rebar and/or mesh do not prevent cracks in the cement, they help to keep the cracks to a minimum. They might add fiber to the cement as another strengthener to the cement. Make sure they install the mesh so it will be centered in the cement and that it is bonded to the pool structure.
