Thread: Calcium levels
    Nov 2015
    Mobile,AL
    12
    Calcium levels
    I have a SWG plaster pool. All numbers are good. Calcium is at 290. Should I keep that around 350 to 400 to prevent plaster damage?
    Thanks
    14000 gallon SWG gunite/quartz plaster,450 swimclear cartridge filters, 2hp pump.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Calcium levels
    yes.
    Dolphin E10 Cleaning Robot.
    JoyfulNoise's Avatar
    May 2015
    13,202
    Re: Calcium levels
    Please post a full set of test results. We can not advise you based on one number.
    There is no such thing as a magic CH number. Scaling of calcium or etching of plaster results from a combination of factors. You can only be properly advised if you post all of your test results.
    Matt
    Nov 2015
    Mobile,AL
    12
    Re: Calcium levels
    FC - 3
    CC - 0
    PH - 7.2
    TA - 80
    CH - 290
    CYA - 60
    Salt - 3000
    Using the Taylor 2006 kit. Water is clear and 62 degrees
    May 2015
    13,202
    Re: Calcium levels
    Quote Originally Posted by mehyler View Post
    FC - 3
    CC - 0
    PH - 7.2
    TA - 80
    CH - 290
    CYA - 60
    Salt - 3000
    So, with your current numbers your CSI is -0.78 which means your water is corrosive to plaster. If you immediately raise your pH to 7.8 with borax, your CSI will be -0.22 which is perfectly fine for a plaster pool. So I have a couple of follow on questions -
    1. Why is your pH so low?? there is no reason to keep cold pool water that low.
    2. Do you struggle with keeping CH up during a normal pool season? I ask because if you get a lot of rain dilution, then I would go ahead and add some extra CH. Where I'm from (the dry desert), we almost never have to add any CH, we get plenty of it from out fill water and evaporation. So I am very leery to tell anyone to add CH when there are easier ways to adjust the CSI (like letting the pH go up).
    Matt
