Results 1 to 12 of 12
Thread: Planning for future electic - lights, outlets etc
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I've heard people say that you should "run conduit" under your decking to all the places you might like lighting or electrical access in the future. What exactly does this mean? Are you actually running wire from the pad/controller to these future spots, or just the tubing underground that will accept the wire down the road?
    We are trying to scale back some of our costs, but I don't want to make things too difficult in the future if we want to go back and add stuff, so I want to be prepared.
    Thanks!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Planning for future electic - lights, outlets etc
    No. Their called "sleeves". It's typically 3" PVC drainage pipe that you bury under walkways so as to not create "islands" of landscaping that are inaccessible to low voltage lighting or irrigation lines. Think of it as an underground tunnel to run services through. Your decking sub should take care of it but he will want/need your input on placement.
    Matt
    JamieP's Avatar
    May 2011
    1,135
    Thanks, Matt! That's exactly what I was needing to know. I thought I was missing something (like the actual term of what I was trying to describe! )
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    I put a lot of this sort of thing under my deck.
    A little different to the approach Matt indicated.
    We used his method to allow for future things that may want to traverse our Driveway and footpaths.
    The approach we took for the Pool deck and captured planter beds was different.
    We planned for the possibility of:
    Irrigation
    Low Voltage Lighting
    Speakers
    115V receptacles
    In our case, these would not all come from the equipment pad.
    So we ran multiple 3/4" conduits from and to the various locations and ran poly line thru them. (<-- Important)
    We also ran extra 3/4" conduits under the deck across the back of our house. These were 'just in case' conduits.
    When you put in these 'future use' conduits make sure you run a string line thru them.
    This is easily done with a vacuum cleaner at one end and a small piece of rage tied to the string line at the other.
    Trying to do this later can be difficult because over the months/years some dirt may end up in the conduits and then trying the vacuum approach will fail.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Apr 2013
    Sacramento, CA
    2,769
    I'm going to disagree with Matt a bit. What he says is best practice for irrigation and low voltage lines. However if you are planing an outdoor kitchen or outdoor lighting and have a fairly specific plan as to where it is going and how it will be controlled you should seriously consider pre placing conduit for that future work. Since the trenches are in this is relatively cheap and can make things easier later.
    I have conduit for a portable spa in place that allows me to place the spa anywhere in my yard
    May 2015
    13,254
    Sorry, I should have been more specific. I was only referring to low voltage electric and irrigation. High voltage AC and gas should always be properly buried according to building code and stubbed out as needed for future use.
    Matt
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Good question, Jamie! I had the same question. So, once these conduits are placed and decking is poured, how do you access them in the future? Do you just have them stubbed so you have access points sticking out??? I'm trying to picture how this is all accomplished and make sure we make provision for ease of access for future plans.
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    May 2015
    13,254
    Quote Originally Posted by Nursenini View Post
    Typically the ends are taped off with red tape and they stick out a little on either side of the poured concrete. Mine are buried under a little bit of fill sand and decorative rocking. So in order to access them, you have to dig down a little.
    Matt
    May 2015
    Lake Elsinore ca.
    48
    Also take pictures of the location such as driveways and walk paths. I also used marking spray paint on the edge of concrete to help locate the conduit later.
    Apr 2013
    Sacramento, CA
    2,769
    This brings up the pictures pictures pictures rule.
    Take pictures of all the blurred lines in the open trenches. Several pictures. This way you know what is buried where so if you ever have to find it latter.
    JamieP's Avatar
    May 2011
    1,135
    Thank you, everyone. This is all very helpful. It sounds like planning ahead is the key, and then taking pictures as backup to remembering where you put everything is necessary too. Looks like we have some thinking to do!
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    I supplemented my photos with some triangulation off two corners of the house.
    Means when you come back to this nice piece of lawn in the future you can take two tape measures and find your spot exactly.
    I find photos only give me a general location to dig.
