Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 151
Thread: Balance pool chemicals
    Nov 2015
    Eagle Point Oregon
    102
    Hi, well I think I finally got help and learned how to post a new thread. So here goes. Pool is 1 yr old, Quartz plaster in ground gunite or shot crete, I used the Colorq pro 7 test kit and have ordered a salt reader from tftestkits.net. here are my readings:
    FC 4.35
    Total C 4.48
    PH 7.6
    TA 81
    CH 548 has been rising since 11-18-15 was 423
    CYA 30
    Pool temp 43
    I think my Ch is very high and TA low
    pool 11-14,IG 16,500G 4ft to 6ft Quartz Tahoe Blue Pentair equip VS pump cartridge filter IC40 SWG Heat Pump Hayward Shark XL Robotic Eagle Point, Or
    Aug 2014
    Northern IL
    4,615
    Re: Balance pool chemicals
    With the water temperature so low, the SWG is not producing so you can just shut it down. Keep your FC levels as a non-SWG pool for now.
    Your TA is fine. Have you added high CH fill?
    Nov 2015
    Eagle Point Oregon
    102
    Hi, This Helps, we put the dummy cell in SWG about a month ago and was wondering if should use readings for a non salt pool now. Pool store wanted me to increase the alkalinity when she was here yesterday and saw my reading. We have done nothing for the high CH. I am not sure what you mean by "have you added high CH fill"? Here are my readings for today, should I now increase TA and should I lower the PH first. Also should I add the TA directly to the deep end and brush the pool with filter running and how long to run filter, I think it said 24hrs . THANK YOU
    FC 4.37 TA 79
    Total Chlorine 4.40 CH 522
    CYA 34 pool themp 48
    PH 7.7
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Your TA is fine. Check out Pool School - Recommended Levels Once you're running the SWG again in the spring, you might even want the TA LOWER. No reason to add TA. TA determines how fast your pH will rise. If you start adding TA to hit some arbitrary number that the pool store wants you to hit, you'll just end up lowering the pH more often, driving the TA down again to a level that allows a more stable pH. TA and pH are directly tied together.
    As far as high CH fill, we're wondering what the CH of your fill water is at. If you added water from a high CH source, that's why it has increased. If not, it's likely being leeched from your plaster or increasing because of fill and evaporation.
    The most important number for pool plaster is not just one number alone, it's the combination of all your levels which gives your overall CSI, calcium saturation index. This number tells you if you're likely to have a stable environment for your plaster, you're likely to etch plaster or if you're likely to have scaling. A CSI between -0.6 and 0.6 is necessary. The closer to 0, the better. Normally your CSI can be kept in a good place simply by managing your pH properly, even with very high CH. Use Pool Math: http://www.troublefreepool.com/calc.html and all your test readings to determine your CSI and look at how adjusting only the pH can keep your CSI neutral.
    Isolated Spa - 345 Gallons
    Feb 2014
    Central Minnesota
    5,080
    Also... mixing our advice and pool store advice will only lead to frustration and confusion.
    Nov 2015
    Eagle Point Oregon
    102
    I was wondering why not to raise the TA since I am at 79 and it says to keep 80 to 120 I am trying to get use to just using this site but still new and learning. Thank You
    Nov 2015
    Eagle Point Oregon
    102
    I forgot something, when I went to pool math it said to add 5lbs today to raise TA I looked at pool school again just now, but I thought I read somewhere on this site to keep TA at 80-120 please help me understand.
    Feb 2014
    Central Minnesota
    5,080
    Please click on the link and read the recommended levels. Pool School - Recommended Levels Where are you getting the 80-120 number? It may have been an old guideline but they have been revised recently.
    Also, they are guidelines, especially with TA. Maintain a TA that allows you the most stable pH. For some it will be 90. For some it will be 60. It's only a bad situation when your TA dips below 50-60 because TA is a measure of the buffering capacity of the water. Its ability to "resist" rapid changes in pH.
    Nov 2015
    Eagle Point Oregon
    102
    Hi, I have been reading so much here and some were old posts but can not remember where I read the higher level of TA. I will stick with the SWG guideline of 60-80 I do have a printout from the PB and it said 80-120, I just looked at it again today.
    Since my water temp is so cold and the salt cell has been removed would I input numbers and look at recommened levels of a non salt pool during the winter????
    Feb 2014
    Central Minnesota
    5,080
    Yes. When your SWG is not chlorinating, you have a manually chlorinated pool.
    Nov 2015
    Eagle Point Oregon
    102
    Thank You so much, that really helps. I do not know the CH level of the water when pool was filled. I have the original printout from the pool store which was Hardness 83 ppm that was 11-14-15. If I tested the water directly from my faucet would that help or work to answer your question.? My first test with the colorq 7 was 11-18-15 reading 423 climbed to 569 11-29-15 we had rain and drained some water last week CH today is 522. I am using puck floater since removing salt cell, and added 2 Cups liquid chlorine about 2 weeks ago. should I take the floater out and only use the liquid chlorine??? I have been thinking of ordering the TF100 but I had a very hard time matching the colors on the drop test I originally bought of course from pool store. I don't know if the TF100 is easier to match up the colors than what I have.
    Aug 2014
    Northern IL
    4,615
    First, I would personally take the floater out and only use liquid chlorine.
    Second, yes, test whatever water you use to top off the pool. That means whatever source you use to add water to the pool. An outside spigot? Let it run for a few minutes before taking a sample.
    Third, is it just the color matching that is difficult for you? If so, the only test requiring color matching with the TF100 is the pH test, so that kit would be great for you!!!
    Nov 2015
    Eagle Point Oregon
    102
    Hi there, ok thank you. we are having rain so it may take me a day or two but I will test the CH at the spigot we used. I will also order the TF 100 soon. I did just order the salt tester. When I order the TF100 I will also get speed stir. Thank you!!
    Aug 2014
    Northern IL
    4,615
    Awesome, Paulette! You will not regret the purchase! The sooner you order and receive it, the sooner we can REALLY get to tweaking your water!
    You will rarely ever have to go to the pool store again! I only go there occasionally for a new brush or something. Ours is a mom and pop pool store and I like to support local businesses rather than buying that kind of thing on-line to save a buck...
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    27,122
    Having your own test kit will save you SO much money and headache!
    For the color matching I have a "trick" to help you................I use a white paper plate!
    I do the PH test over my stove using my bright hood light. I hold the tube in front of the plate at about waist high. I pull the plate back and forth until I can see the color match. That has helped me quite a bit and my pool is like a jewel.
    Make sure to get your test kit ASAP. That way you can start learning how to use it and have it ready when you need it come warmer weather.
    Kim
    Nov 2015
    Eagle Point Oregon
    102
    Thank You for the tip!
    Aug 2014
    Northern IL
    4,615
    Please let us know when you order your kit, Paulette. We are excited to help!!!
    Nov 2015
    Eagle Point Oregon
    102
    Hi, I ordered the tf100 with speed stir this morning. I received the salt kit yesterday, plan to try it out today. I had already ordered the colorq 7 last month but after more reading decided to use both. I love the colorq but with the reviews here I am not sure if the readings are correct. It is so easy to use. Someone needs to come up with one just like it that can be trusted.
    Jul 2012
    Tallahassee, FL
    27,122
    I am so very happy to hear this. It will be so much easier.
    While you are waiting you can go get a cheap, white, plastic plate to help you do the PH test. You can use a paper plate but...I like the plastic one better as it firmer to hold up.
    Kim
  20. Back To Top    #20
    Nov 2015
    Eagle Point Oregon
    102
    I used the salt test kit drop test not strips worked great and very easy, and salt level is 3400 hope that is ok dummy cell has been in since 10-14-15 and I should now look at pool math and use the none SWG readings for FC ect correct?
