Thread: Can the CYA stay lower in the winter?
    Jun 2014
    Houston, Texas
    475
    the water is cold. Our FC has been 3.5-5. Last water reading was tonight and is:
    FC 3.5
    no CC
    CALC 300
    TA 60
    CYA 40
    pH 7.5,6-ish
    Water is crystal clear. Just wondering if it's okay to leave the CYA where it is for now.
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Can the CYA stay lower in the winter?
    Yes, that should be fine. The active chlorine level is lower at lower temperatures (for the same FC/CYA ratio) and there's less sunlight on the pool so a higher CYA isn't needed. You can raise it higher when you open in the spring.
    langerking's Avatar
    Jul 2013
    Clermont, Florida (that's near Disney World)
    104
    Wait, 40 CYA is low? I thought that is about perfect. I always try to target 40.
    Nevermind - just realized you are on a SWG system.
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    5) Hayward 1.5 hp DE 3600 72 GPM
    Taylor K-2006
    STA-RITE Great White GW9500
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    40 is kinda low for HOUSTON in the summer for FC related burn off depending on amount of full sun.
