Results 1 to 8 of 8
Thread: How does FC stay this high?
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    FC is staying high with SWG set at 5%. See #'s below.
    PH 7.5
    FC 9
    CC .5
    CH 375
    TA 80
    CYA 90
    Temp 58-60
    Running pump 8 hrs/day
    Why does FC stay this high at 5%?
    Thoughts?
    Thanks!
    32 x 15 15500 gal. IG gunite, 6 ft. round attached spa, diamond brite 2 plaster, flagstone coping w/concrete spray deck, IntelliChlor IC-40 SWG, 2 hp Max-E-Pro pump, 450 sq.ft. System 3 cartridge filter, 400k Max-E-Therm NG heater, automation is IntelliTouch i7+3, Polaris 280 pressure side cleaner,
    TS 100, Borax
    Jun 2011
    Long Beach, CA
    2,781
    Re: How does FC stay this high?
    As the sun gets lower and lower in the sky, less UV is making it to the pool and chlorine usage is drastically reduced. Basically everything that consumes chlorine is not making its way into the water during this time of year.
    I would cut the run time down to 2 hours for your pump and adjust the SWG as needed.
    JoyfulNoise's Avatar
    May 2015
    13,194
    In all likelihood your SWG is probably not running due to cold water. So in effect, your 5% is probably closer to 0%.
    You should not have to run your pump 8 hrs/day. Cut it down by half. If your water clarity and cleanliness is still good, you can cut it down further. Also, run your pump in the later part of the day when the water is warmer. No need to run it overnight or on the early mornings when it's cold.
    Matt
    Jul 2015
    Central Valley CA
    1,107
    My FC had not dropped even .5 PPM in the last 2 weeks (pool only gets a couple of hours of sun at the moment and only part of the pool at that) Water temp around 49F. Was getting worried about my testing till this weekend when my wife was doing some gardening and got some dirt in the water, dropped the FC by 1.5 PPM in 24hrs. She told me she was helping, making sure my testing was accurate.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Thanks for all the good input. I think I will cut run time at first to 4 hrs and check clarity after that then further if needed. Lots of leaves dropping this time of year so that may be a problem with reduced filter time. I will keep Polaris running 2 hours/daily and see how it all shakes out.
    Again, thanks!
    TS 100, Borax
    Jun 2011
    Long Beach, CA
    2,781
    Quote Originally Posted by bware View Post
    Again, thanks!
    Think about getting a robot for your next cleaner, no need to run the pool to keep it clean.
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    I thought about that this past summer. Which one do you recommend?
    TS 100, Borax
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Sounds like it's time for a new thread in the pool Cleaner Forum!
