Thread: Dan from Michigan
    Dec 2015
    Michigan
    2
    Dan from Michigan
    I bought an inflatable spa on a whim (I don't have the time or funds to install a real one), but even though my spa was cheap I want to maintain excellent water quality!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Dan from Michigan
    Hi there! I think a spa would be even more important to maintain as well as harder as it is such a smaller amount of water. What test kit are you using?
    Kim
    Casey's Avatar
    SW PA
    10,438
    Well, you've come to the right place since we have a spa forum. Welcome!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Check out the two stickies in the Spas and Hot Tubs forum. Either method will work as long as you have a decent test kit and stay on top of maintenance.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I am a big fan of the dichlor then bleach method, it has been really great for us for two years now. Hot tubs make winter a lot better!
    How do I use Chlorine in my Spa (or pool)?
