Results 1 to 11 of 11
Thread: Vinyl liner installed over light
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    200
    For some reason the previous owners had the liner installed over the pool light. Thoughts on if the light could be but back in service without having to replace the liner? My assumption is the light is not functional and instead of fixing it, they just went over it. Thanks
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    Aug 2014
    Northern IL
    4,615
    Re: Vinyl liner installed over light
    Even a non-functional light could be cut-out of the liner. Hmmmm. How far below mid-skimmer is the bottom of the light housing?
    Jun 2015
    York SC
    200
    I would guess about 2 feet. I see where you are going. I have been told to only drain to the top of the 2nd step and I know the light doesn't show up at that point. Could be more like 3 feet. I will measure in the morning
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    I would wait until warm weather to do anything about it. They could have had a leak in the light niche that they didn't fix. If you don't know the age of the liner, waiting til warmer weather is better as the liner will be more pliable at that time.
    Love TFP? Become a
    TFP Supporter!
    Aug 2014
    Northern IL
    4,615
    Zea is so right.
    I wonder why you were told only to drain to the top of the second step. Do you know if you have a high water table? If so, this situation would have to wait past spring when the ground water lowers.
    Jun 2015
    York SC
    200
    Looking at some data, looks like the water table is at about 19 feet right now. I am not planning on doing anything right now, just working on my pool to do list and was wondering if it would even be feasible. Is the niche lined with the liner or does the liner go around the niche and then the niche has to be waterproof on its own. In other words wondering how big a deal it would be if the niche was leaking?
    Aug 2014
    Northern IL
    4,615
    The liner is normally cut around the light The liner does not go behind the vertical surface in any way. The niche is then included in your pool circulation, although minimal circulation. If there is a leak there, then it could be a problem. With your water table currently being low, you have options.
    Jun 2015
    York SC
    200
    Thanks for the info, I think this will go further down on the list, sounds like one of those things that could be simple, or could get really messy. I have a whole list I can easily prioritize over this, like a swg.
    Aug 2014
    Northern IL
    4,615
    Okay then. Let us know if we can help in any way.
    Diver's Avatar
    May 2011
    South of Boston
    450
    not to hijack the thread, but is it ok to have liner over the non-functional light?
    when it's time to change my liner, i thought to have the light niche filled first and the covered with liner. but if leaving the light there is acceptable it might reduce the cost of replacing the liner for me. not sure how it would look though...
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Jun 2015
    York SC
    200
    Visually it is barely noticeable, I didn't even know it was there until the first time I brushed the pool. I hope it is OK cause that's what I have.
