Results 1 to 13 of 13
Thread: pool heater after plaster
    Oct 2015
    humble texas
    132
    I read that you can't put on a pool heater after plaster. Is this true if so what plaster? Even Pebble Finish?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: pool heater after plaster
    How are the pebbles held in/on? Plaster. You will still need to brush it as it cures. There will be plaster dust. It is my understanding (I could be wrong) it is the plaster dust that causes the problem with the heater.
    I do encourage you to do a search to make sure. I would also ask your PB. He is holding the warranty card so.........he words trumps ours!
    Kim
    JoyfulNoise's Avatar
    May 2015
    13,247
    There's two problems that can occur - a traditional plaster start which creates lots of plaster dust OR an acid start which eliminates plaster dust by dropping the pH very low. Both of those situations would be bad.
    Since you should not use the heater while the plaster is curing, it's just good practice to leave it disconnected and bypassed.
    Matt
    Oct 2015
    humble texas
    132
    So far how long do we have to wait before we can heat
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    May 2015
    13,247
    See the TFP Plaster Startup Guide in PoolSchool for details. As Kim said, double check with your PB or the plaster subcontractor.
    Matt
    There are several issues related to the heater.
    1) Plaster dust can scale the heat exchanger where water temperatures are higher than ambient.
    2) Hotter water in the pool increases the risk of scaling in general by increasing the CSI.
    3) Hotter water increases carbon dioxide offgassing, which raises the pH, and increases the risk of scaling.
    Typically, you want to wait until the chemistry is well controlled and all plaster dust is gone. Three weeks should be sufficient if you follow good procedures.
    Can you post all water chemistry results?
    How hot do you want to go?
    Support the site
    Jul 2012
    Tallahassee, FL
    30,585
    Call your heater warranty to see what THEY say. Notice that I am not willing to tell you "You can run your heater ?? days after filling". I do NOT want you to say "But Kim said I could" if something goes wrong
    Hugs! I know you want to get in a warm pool as soon as it is finished! Guess you have to think long term over short term.
    Kim
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Our PB says 30 days.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    May 2015
    Lake Elsinore ca.
    48
    Our PB Wouldn't even plumb the gas line to the heater till weeks later. He said it help with eager new pool owners not to run during plaster curing.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by kimkats View Post
    Some day a pool warranty will say "ok to run it this way ... if Kim says so."
    Dolphin E10 Cleaning Robot.
    Jul 2012
    Tallahassee, FL
    30,585
    Quote Originally Posted by borjis View Post
    YEA! Think of all of the people who will love me! Ms. Want It NOW so will let everyone do what they want NOW!
    Kim (thanks for the laugh!)
    May 2015
    metairie
    27
    I ran mine a week after plaster.... I am the pool guy though . I did ask the plaster guy and he said go for it. I am not telling you to do it but I had no issues at all. I would do what the pool guy says so you stay in warranty.
    Shotcrete 21x11 pool with raised 11x5.5 hot tub, 7' spill over. 1"x1" lunata bay mosaic tile and travertine coping. (Not sure of plaster yet) 1hp whisperflo pump for returns and water feature. 3hp whisperflo for 6 waterway jets in hottub. 3 jandy nichless lights. Hayward T-9, PS4, TA60 sand filter. Broke ground Aug 5, 2015 Aiming to be done Sep 10, 2015
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    A lot of issues like these are "best practices". Will your pool collapse if you don't follow them? No. Will some aspect, or aspects of it be compromised to some degree? Sure, probably. Completely not helpful I realize but just a perspective.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
