Thread: What is the purpose of this hose?
    There is a very thin, flexible black hose that ties into two different above ground PVC pipes for my pool pump. The plastic connection between the hose and the PVC pipe (shown in the picture) has cracked and my pool plumbing can no longer keep pressure. I would like to get this part replaced but I don't even know where to start.
    Can someone explain the purpose of this hose and where I can find the replacement parts?
    Re: What is the purpose of this hose?
    It went to a Hayward CL-220 tab feeder. If the feeder is gone. someone probably just connected the in and out with one line.
    Support the site
    wjr75's Avatar
    Jun 2013
    IL
    836
    Yes that is what I have feeding my tab feeder also when I actually use it. I'm sure you can buy a plug where the hose is attached to the PVC.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    It's a 3/8" hole. You can drill, tap and plug, you can glue a patch over the hole, or you can replace the tubing and fittings.
    Support the site
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I had that setup when I bought my house.
    Tab chlorinator disconnected and one pipe connected to the other...it was in an annoying place that I feared breaking
    the line when doing maintenance, so I unscrewed the tube, then cut the tube leaving about 2 inches left one each pvc connection, then put them
    back in and plugged them with liquid nails adhesive and stainless steel bolts, then used small automotive hose clamps to cinch
    down the 2 inches of tubing sticking out to the glued bolts...worked like a charm.
    I did this so if I ever do a stenner chlorine feeder I won't have to re-tap the pvc.
    Dolphin E10 Cleaning Robot.
