Thread: Is Pool Math working correctly
    Dec 2015
    Canada
    2
    300 Us gallons to lower PH 7.8 to 7.4 it says add .8oz MA
    1136 litres to do the same it says add 84 ml
    .8 oz should be 23 ml?
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: Is Pool Math working correctly
    Quote Originally Posted by Soak View Post
    Can you post your all the numbers you've entered into the "NOW" column so we can check? Also, is the type of MA set the same in both cases, 31.45% - 20 Baume?
    Matt
    Dec 2015
    Canada
    2
    4, 7.8, 50, 150, 30, 0, 50
    31.4% MA in both.
