Thread: Testing green water
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Testing green water
    This is a hypothetical question. If I open to a green pool next spring (I hope not), my question is, how do the chemicals from a Taylor Test Kits react with the green water? Do the chemicals make the green water turn into clear water in the testing process? If you are checking PH and water is green, will the reagent give you the proper reading? Sorry if this a dumb question, just something I been thinking about!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,432
    Re: Testing green water
    That is an awesome question and I know the answer! It will NOT change the test results at all!
    When you pull the water from the pool it will not look as bad as the overall pool. In fact it will look almost clear in the tube.
    Even the CYA test, when done a on cloudy pool, will still be valid.
    Kim
    30,409
    Yes! Ms. Kimkats certainly does know the answer.....I second it!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Just the answer I was hoping to get, Thanks! Now just.........COME ON SPRING!!!!!
    Mark
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Only 105 days until Spring!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
