Thread: Pool Math conflict
    Oct 2015
    Katy/Texas
    411
    Pool Math conflict
    I have been using the Pool Math online application on my iPad for quite some time. Very helpful in understanding the chemistry relationships.
    This morning the app recommended (in the pink section) that I add 97 oz of MA to drop pH from 8.2 to 7.6.
    At the bottom of the app (Effects of adding chemicals) it says that 97 oz of MA will drop pH 1.3. That is twice the drop shown in the pink section of the app.
    Please help me understand the conflicting values.
    Thanks for the crystal clear water in my pool.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    38,246
    Re: Pool Math conflict
    The top takes your actual TA level into account. The bottom does not and makes general assumptions. There is a note by the effects of adding chemicals that says it should not be used for large pH adjustments.
    Trust the top.
    Oct 2015
    Katy/Texas
    411
    Thanks for the clarification.
    I was confused by the conflicting values.
    Aug 2014
    Shallotte, NC
    693
    I would suggest, when making large adjustments, to put in half the predicted amount and re-test. It is better to "sneak up" on the goal rather than to overshoot it.
